Extended Rear Shocks
Discussion in '3rd Gen. Tacomas (2016+)' started by MxRyder114, Sep 6, 2019.
  1. Sep 6, 2019 at 12:58 AM
    MxRyder114
    MxRyder114 [OP] Member
    I just ordered up a pair of the fox 2.0 RR shocks and a 1 inch block for the rear. Upon inspection it says the foxes are for a 2-3 inch lift. Question is, will I have a problem running a 1 inch lift on a shock that is made for a 2-3 inch lift? My apologies if this has been talked about before, couldn’t find any other information. Just want to make sure no damage is being done. Cheers
  2. Sep 6, 2019 at 1:00 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    I would assume you might just have a bouncier ride since the shocks will be longer than what they’re needed for and may wear them out faster. Good news is blocks run pretty cheap. I’m sure you could get a 2” lift block for around $80.
    MxRyder114 [OP] likes this.
  3. Sep 6, 2019 at 1:04 AM
    MxRyder114
    Was hoping to stay at 1inch in the back, only have 2inch lift in the front and like it to sit level. Also not too comfortable with throwing on more than a 1 inch block for axle wrap purposes
  4. Sep 6, 2019 at 4:47 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Stockton
    2000 4runner
    91 Octane
    List the part number of the shocks you ordered.
  5. Sep 6, 2019 at 7:50 AM
    MxRyder114
  6. Sep 6, 2019 at 3:47 PM
    hawaiidclb
    hawaiidclb Well-Known Member
    Maui, Hawaii
    08 Black DCLB 4x4
    Subbed for answer
  7. Sep 6, 2019 at 3:53 PM
    ArizonaNativ
    ArizonaNativ Well-Known Member
    Tucson
    As long as under full compression you are not bottoming out the shock and full extension you are not pulling out brake lines I would think you would be fine.
    Skydvrr, MxRyder114 [OP] and whatstcp like this.
  8. Sep 6, 2019 at 3:55 PM
    ArizonaNativ
    Tucson
    Not sure why ride would be bouncier? I am not aware of rebound progressive shocks. I would not think the shock being a little more in its compression state would create a different ride quality.
  9. Sep 6, 2019 at 6:46 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2019 TRD Pro
  10. Sep 6, 2019 at 6:48 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    AND OVER EXTENDING PARKING BRAKE. Just to add.
