Extended Tacoma Warranty Not So Good
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcraig49, Dec 29, 2009.
  1. Jan 8, 2010 at 3:55 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    A'Hem!
    Glad it worked out in the end!:D
  2. Jan 8, 2010 at 7:24 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I submit that your comment is propably appropriate for the V6 but the 30,000 and 60,000 service described in the Owners Manual for the I4 is essentially change the oil, rotate the tires, change the filter for the air conditioner that's located in the glove compartment and check fittings, brakes, etc.. The plugs and the transmission fluid are rated for 100,000 miles and there are no zerks to lubricate. I am driving an '09 and do not plan to pay hundreds of dollars for that service. The dealer will try to sell me a fuel system treatment that I won't need since Shell is the only gas I put in the truck.
    As for extended warranties:
    If they didn't make money on them they wouldn't sell them. Put the cost in a CD and pull it out if you need to make a serious repair.
    YMMV
  3. Jan 8, 2010 at 9:23 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    yea go to a different dealer.
    My transmission went out after I, well, uh, uh, I plead the 5th on that one; but Toyota replaced it under the extended warranty with no problems.
