Extended Travel Coilover Length
Discussion in '1st Gen. Tacomas (1995-2004)' started by rcracin, Nov 12, 2019.
  1. Nov 12, 2019 at 7:57 AM
    rcracin
    rcracin [OP] Well-Known Member
    Does anyone know the length of extended travel coilovers? I gave a set of SAW coilovers lying around that are 22” long and I’m wondering if they can be used along with a set of SPC UCA’s. Thanks
  2. Nov 12, 2019 at 8:08 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Google or call manufacturers.
    I just looked up Fox 2.5 EXT CO on a vendor site and it's listed as
    14.55" compressed length
    20.04" extended length
    5.49" travel
  3. Nov 12, 2019 at 9:24 AM
    rcracin
    Thanks. A follow up question in this case. Is 22” too long?
  4. Nov 12, 2019 at 11:40 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    How are you measuring? Should be top of the top hat to center of the lower bolt.
    That measurement should be around 20"
    If that's how your measuring, and it's 22", you're going to run into CV and tie rod binding issues. Could run limit straps, but I would also wonder if your collapsed length will be too long as well.
