Extended Warranty
Discussion in '4 Cylinder' started by tango59, Jul 19, 2012.
  1. Jul 19, 2012 at 4:05 PM
    tango59
    tango59 [OP] Well-Known Member
    Memphis, TN
    07 Base 4X4
    I just bought an 07 regular cab 4X4 with 82k miles. The truck is extremely clean, looks to be regularly maintained and garage kept. I keep going back and forth about buying an extended warranty. I guess I need to find out if there's a remainder of a factory drivetrain warranty. Any thoughts ?
  2. Jul 19, 2012 at 4:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    No to extended warranty. Change transmission fluid and differential to synthetic fluid asap. [​IMG] I'd run LUCAS fuel system cleaner for a tank or two then install new spark plugs.
  3. Jul 19, 2012 at 5:19 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    2007 with 82k on it?
    You've got a 5 year old truck with over 36000 miles on it. Even the Federally mandated emissions parts warranty is done.
