External Thermometer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by big_jarv, Aug 23, 2016.
  1. Aug 26, 2016 at 11:43 AM
    dedmouse
    dedmouse Well-Known Member
    Dammit
    South Central Missouri
    2010 Black Tacoma Base, 6 spd manual tranny, V6.
    Wow! Thank you! I think I'll order my temp monitor this weekend. The one that is in my wife's car has been a life saver. Here in Central NH, the temps at the road level can hover right at the freezing mark and if it starts to rain, it will freeze as it hits the asphalt. My old Wrangler didn't have a temp sensor in it...I took a few slides down the road because of it. I learned to tell when the road noise diminished, I was probably on black ice.
  2. Aug 26, 2016 at 12:11 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Yeah we get black ice here too.
    Good luck this winter and keep the shiny side up and pointin straight down the road.
  3. Aug 26, 2016 at 2:31 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I went original and installed a factory display from an early model in my overhead console
    Norton likes this.
  4. Aug 26, 2016 at 5:23 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I contacted Bob at bobs mirrors and got a Gentex with an external temp sensor. $130 and looks like OEM. Bob is very knowledgable too, I recommend him without a doubt.
  5. Aug 26, 2016 at 5:40 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1. That's the general area where I installed the probe on my 1st Gen. It works well as long as you're moving and/or the engine is running because that keeps air moving around the probe. When you park, however, the "heat bubble" around the engine will cause false high readings until you get the air moving again.
    +1 for Bob (aka @RJP869). I just upgraded my rear-view mirror with one from him. He provided solid advice throughout a smooth transaction.
  6. Aug 26, 2016 at 8:31 PM
    dedmouse
    Dammit
    Bear with me...I could answer a thousand questions about Jeep TJs but this Tacoma thing is very new to me. My 2010 Tacoma is a base model...it came with no compass/outside temp installed but it does have backup camera in the RV mirror. Is the wiring already installed in the truck in the vicinity of the rearview mirror so if I find a used one in a scrapped out Tacoma somewhere, will it fit (and work) if I were to swap it with the mirror in my truck right now?
  7. Aug 26, 2016 at 9:37 PM
    Norton
    I'm not familiar with 2010 MY details/wiring but, according to the brochure, an "electrochromic mirror with integrated backup camera monitor" was part of the SR5, TRD OR, and TRD Sport packages; and was standard equipment on the X-Runner. It connects via a 14-pin wiring harness that extends down from above the headliner. The mirror-side connection is the white receptacle at the center, top of this photo:
    The more difficult question is, if the plug is present in your truck, what connections are ready for use and which ones aren't. (e.g., The temperature probe may not be present behind your grill.) Note also that you may have a hard time finding an inexpensive mirror upgrade. Depending on specific features (e.g., monitor, temperature, compass, HomeLink, etc) and vendor, they range in price from a couple hundred to several hundred dollars.
    TRDSport10 likes this.
