Extra tailgate security (not the clamp)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Robocop, May 2, 2009.
  1. May 2, 2009 at 6:54 PM
    Robocop
    Robocop [OP] Well-Known Member
    Alabama
    09 4x4 Access Cab Gray Manual
    In addition to the hoseclamp method I added 2 cable locks to each side of my tailgate. This adds two more points to go through if a thief really wants your tailgate. I used 3/32 galvanized rubber coated cable with two of the 3/16 cable bolt down locks. I believe total cost to me was under 2 dollars. The bolt down locks attatch the looped ends together and if you crank them down pretty good they will hold and are a bitch to get undone in such a small space....with not much slack in the cable. Make sure the cable is coated with the thick clear rubber as not to scratch the paint or cause rusting later.
    I tried to cut the cable with standard wire cutters and it did not work and it took me about 5 minutes to cut it with a hacksaw blade. Not foolproof by no means however just a little more for a thief to go through. This works well and does not bind at all when I shut my gate. I attatched the cable to the tailgate hinges and then through the tie down hooks on my bed....not sure if other 2nd gens have these but mine did and they are a star bolt pattern....pics below.
  2. May 2, 2009 at 6:56 PM
    JAG
    JAG Well-Known Member
    Good idear!! :D
  3. May 2, 2009 at 8:26 PM
    Robocop
    Alabama
    The cable was 34 cents per foot and I got a 2 foot section with the cable locks at 54 cents each. Lowes had all of it as well as the hose clamp I also just installed.
  4. May 2, 2009 at 8:31 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Great idea, I used the hose clamp and than installed a large washer over the keyhole shape on the support cable. Thief would need a torx key to remove.
  5. May 2, 2009 at 8:33 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    nice mod
  6. May 2, 2009 at 8:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good mod man. that should go in the cheap/free mod thread. send a pm to piercedtiger and see if he'll add it. its mod worthy!!
  7. May 2, 2009 at 8:58 PM
    Robocop
    Alabama
    Sent a PM and maybe it can be added or even improved upon by other members.
    I got the idea after realizing adding a second hose clamp to the drivers side did nothing to prevent that side from being lifted. I figured that by making both sides hard to remove could only help.
    You may be able to use a larger cable however from what I can see the size I used fits well after the tailgate is closed. The small loop folds into the space between the gate and body and should cause zero damage or obstruction. The smaller you can make the loop the better it should secure.
  8. May 3, 2009 at 10:14 PM
    AZsand
    AZsand Well-Known Member
    ...handcuffs would've been bitching...nice work.
    TacoNorth2010 likes this.
  9. May 3, 2009 at 10:20 PM
    Robocop
    Alabama
    I agree the handcuffs would have been a nice touch however my opinion for the best security option on my tailgate is a lock known simply as the H&K 40 Cal. USP.....:D
  10. May 31, 2009 at 5:45 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Fletch, could you explain this in more detail? Do you have a picture?
    Wytwkkr likes this.
  11. Aug 18, 2015 at 9:24 PM
    2013 on 35s
    2013 on 35s New Member
    2013 tacoma
    Any pictures of the cables? Cus i have no idead how they look
    Wytwkkr likes this.
  12. Jan 5, 2020 at 11:37 AM
    Kevin B
    Kevin B Member
    Kevin
    Long Island NY
    Tacoma Sport TRD V6 4x4
    None
    I got mine at a bicycle supply shop. Looked at each end and the come in various lingths. Also available at Home Depot, Lowe’s. And Walmart.
