Extra toggle switches for us
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnh7, Jun 11, 2011.
What do you think of this mod
  1. Clean & Usefull
    90.8%
  2. Clean & Not-usefull
    2.1%
  3. Tacky but usefull
    6.4%
  4. Useless mod all around
    2.1%
  1. Jun 21, 2011 at 7:44 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Did you paint the panels left and right of the radio or did you purchase those separately?
  2. Jun 21, 2011 at 9:31 AM
    johnh7
    johnh7 [OP] life. It goes on.
    GA
    i painted the ac control panel, and the head unit dash kit blue, its clearcoated and polished.
    then the 2 mid vents is one piece that comes silver from the factory unless u have the base model then it comes black, but when i took the dash apart to get to the panel were i added the toggle switches i took it out, preped and painted it black cuz since i painted the other 2 panels blue that silver was out of place.
  3. Jun 21, 2011 at 9:37 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    subd :popcorn: looks good man!!!
  4. Jun 21, 2011 at 10:12 AM
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    Wow, that looks great. Is there a write-up on how that panel where you have your switches come off?
    Totally off topic, does the Chevy Colorado 3rd breake light fit? Is there a write-up on the mod? I would love to have cargo lights.
  5. Jun 21, 2011 at 10:23 AM
    johnh7
    GA
    i can make a write up on how to make the colorado light, its realy easy but i think theres already one out there... and to get that panel off u have to remove, glove box, drivers kick panel, drivers under panel, gauge cover, Head unit, ac controls, and the 2 inner vents...
    if you have a haynes manual it will tell you...
  6. Jun 21, 2011 at 10:30 AM
    Scooter
    Manitoba, Canada
    Thanks!
    Really interested in the Colorado third brake light. is it a direct fit?
  7. Jun 21, 2011 at 10:39 AM
    johnh7
    GA
    no not direct fit u have to cut aprox 1"sq on each side then drill wholes and insert the factory plastic screw tabs that ur truck has and cut the factory plug off the OEM 3rd brake light and wire it to the new one then ground the cargo lights to the bake light ground and run a hot wire from the back through the headliner down the drivers side rear and through the channel up to were ever your putting a switch to it. look at my build and i show u some more pics on it if interested.
  8. Jun 21, 2011 at 10:51 AM
    Scooter
    Manitoba, Canada
  9. Jun 21, 2011 at 10:54 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    very good job,i like it
  10. Jun 21, 2011 at 11:19 AM
    nyfishhunter
    nyfishhunter Well-Known Member
    Sean
    White Plains, NY
    2010 DC 4x4 OR Pyrite
    Weathertechs, Pop N Lock, Whitetail Sockmonkey, OEM bed mat, Undercover SE, Wet Okoles, OEM iPod interface, Rear Spring TSB, Illuminated 4x4 switch, DTRL, Timbrens, 5100s (front .85), Eibachs, 1.5 AAL, OEM running boards, FJ TRD center caps, diff breather mod, trimmed front flaps, ImMrYo mirror bracket, Grillcraft, painted white Sport grill black
    Would these switches be plug and play for Tacomas with the existing fog light switch? It would be nice to be able to see when they are on.
  11. Jun 21, 2011 at 11:22 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    love the switches, hate the blue
  12. Jun 21, 2011 at 11:33 AM
    johnh7
    GA
    for hookedontronics--- to each its own buddy....
    for nyfishhunter--- no because these are a 6pin plug not a 4pin like the OEM fog light switch is, but it wouldnt be hard at all to add... because all you would need to do is ground the switch like shown on my schematics pdf i posted and ull be good. the pdfs are located on page 1 posts 14 and 15 of this thread.
  13. Jun 21, 2011 at 1:27 PM
    nyfishhunter
    Sean
    White Plains, NY
    Thanks for the information. For what is worth, I really like and appreciate the work you've done on your truck. I am still amazed a creative ideas people continue to think-up and the guts people have to tear things apart and actually do it!
  14. Jun 21, 2011 at 3:38 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    are there OEM fog light/light switches that fits the smaller holes below the radio???????????
  15. Jun 21, 2011 at 3:41 PM
    #35
    Jerez
    Rod
    Ontario Ranch
    Estock
    nope, the ones down there are a bit smaller. :cool:
  16. Jun 21, 2011 at 3:58 PM
    #36
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    looks nice man! un like some others i think it looks clean. and is very usefull!
  17. Jul 10, 2011 at 1:06 PM
    #37
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    x2
  18. Jul 19, 2011 at 2:23 PM
    #38
    Sgian
    Sgian Dark humor is like food, not everyone gets it.
    Louisiana
    2011 Sport DCSB Manual V-6 SC
    TRD Super Charger, URD 2.8 Super Charger Pulley, URD headers and full system, URD fuel pump upgrade, URD Short throw Shifter, AFE CAI, OME 886 coilovers with Nitrochargers, Dakar Leaves, Desert Products UCA's, FJ TRD Anthracite rims, BFG AT/TKO 285s, Redline Hood struts, Weathertech Ventshades, Weathertech Floormats, Speed Dawg shift knob, Coupe solid shifter, Relentless all around, Eyelids T2, Mr Yo Rearview mirror lift, ejector seats, Rigid D2s front and back, Rigid Light bar in skewp.
    sub'd
  19. Jul 19, 2011 at 6:50 PM
    #39
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    what kind of usb ports do you have and where did you locate them?
  20. Jul 19, 2011 at 6:53 PM
    #40
    johnh7
    GA
    look at the last pic from post #1 and ull see 2 cut outs right under the CB mic hanger...
    I bought some cheap ebay cig lighter ones and tor them apart.
    #40
