Extra weight for driving in snow&ice
Discussion in 'Performance and Tuning' started by colo plainsman, Sep 9, 2012.
  1. Sep 9, 2012 at 4:44 PM
    colo plainsman
    colo plainsman [OP] Active Member
    Colorado
    01 double cab SR5 TRD 4wd
    How much extra weight do you add to the bed of your truck for driving on iced and snow packed streets. I have considered using sand for extra weight any other options.
  2. Sep 9, 2012 at 4:48 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    None. 4wd works fine for me here in icy VT/NH.
  3. Sep 9, 2012 at 4:57 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    If you search on here, lots of folks use the sand bags from lowes. Depending on how much snow you get, id say 3-4 should be good over the rear axle
  4. Sep 9, 2012 at 4:58 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    i use to own a 2wd pick up and i added about 200 pounds sand bags and it made the worlds difference, but now with 4wd and a toolbox in the back i dont need it.
  5. Sep 9, 2012 at 5:00 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
  6. Sep 9, 2012 at 5:02 PM
    colo plainsman
    Colorado
  7. Sep 9, 2012 at 5:02 PM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    4 x 50 lb bags work great for me. Not sure I really need them, but I always throw them in the back just in case.
  8. Sep 9, 2012 at 5:05 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  9. Sep 9, 2012 at 5:09 PM
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    So many threads it's hard to know if a topic was covered, the only reason I knew was because I responded to it.
  10. Sep 9, 2012 at 9:52 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I throw 300lbs of sand bags in the back when I go up in the mountains.
  11. Sep 9, 2012 at 10:24 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I used to use 3 - 50lb sandbags when I had the original tired that came with the truck. The older they got, the worse they were.
    About a year ago, I bought new tires and don't need the extra weight.
    The new tires work great!
    Instead, I'll lower the air pressure slighty in the rear tires.
    When I ran with 150lbs of sandbags, it killed the gas mileage.
  12. Sep 9, 2012 at 10:24 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My 250 lb cap is perfect for keeping weight over the rear tires
  13. Sep 9, 2012 at 10:28 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    a lot of guys get 3 or 4 tube sand bags. i plan on getting a tool box very soon. so i may only get 2. also even with 4wd weight in the bed will help! the backs of truck as very light, and the 05+ are even lighter.
  14. Sep 10, 2012 at 5:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I used to add between 2-300 lbs of either steel tractor weights or tube sand at the front of the bed. I don't put weight over the axle because if you ever have to lock up the brakes, that weight will be coming through the rear window.
    I now have a shell and a plywood platform in the bed so that extra 300 lbs does the trick.
  15. Sep 10, 2012 at 5:23 AM
    Bassetdad
    Bassetdad What if God Smoked Cannabis
    Harrison, Ohio
    2001 De-Badged SR5 Access Cab 2.7 / 5m
    Access Tononu Cover AFE Pro-Dry S Drop-in Filter American Mag Wheels Bilstein 5100's Black Billet Grill Clear Taillights Perma-Tech sprayed Kennesaw Mountain Rear Bumper Michelin Tires PIAA Driving Lights PIAA Headlights Piaa Tail Light Bulbs Tinted Windows – 50% Toytech AAL URD Short Shifter Tranny - Mobil 1 Engine - Mobil 1 Custom Three Bike In Bed Rack New Toyota Undercoated Frame Clear LED 3rd Brake Light
    None, never had a need for them in Ohio. The 4x4 does the job.
  16. Sep 10, 2012 at 5:23 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Just remember to lock your load down like Pugga said and remember any additional weight you add will increase your stopping distance. I'd much rather stop quickly then start quickly, but to each their own.
    IMHO adding weight is not needed in my truck. The mods I have done keep my wheels going just fine.
    Also if you are adding weight like sand do yourself a favor and do 50% sand 50% salt just in case. That's what I used to do with my Mustang and it saved my ass in a few ice storms.
    Here is what the USPS uses in their rigs :D
    http://www.puzzleweight.com/ordersets
    reason I don't add weight.....I don't need it ..
    stock tires, no weight, 20psi, pushing snow like a champ
    high center on a snow drift.... wheels 2-3' off the ground. the only time snow usually delays me
  17. Sep 10, 2012 at 8:56 AM
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    you don't need weight if you have a good set of winter tires. i don't add weight to my truck but i do run a winter tire and i do just fine in all but the deepest snow
  18. Dec 20, 2014 at 2:49 PM
    dcous
    dcous Well-Known Member
    Casey
    Anchorage, AK
    07 taco 4wd 2.7 manual
    I have a set of studded duratracs on my 2nd Gen access cab. It was spinning more than I'd like in 2wd so I added 300lbs of sandbags including a plastic container box (got all at Home Depot) filled with half salt/sand. It made a noticeable difference in traction. In Anchorage we have a lot of ice on the intersections in town so it helps alot.
  19. Dec 20, 2014 at 3:21 PM
    cdthiker
    cdthiker Well-Known Member
    Tim
    WAY north Idaho
    2012 Tacoma RC 4X4 5speed
    I bet between the cap and the sand bags I have about five hundred pounds back there. Out here they dont even plow unless there is at least 4 inches out of town or three in town.
    I live out in the sticks a bit and have not seen a plow all season. Some times there is 6 inches of crap on the road. It makes for a lot less 4x4 usage
