extreme shudder when braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by malander, Nov 5, 2010.
  1. Nov 5, 2010 at 5:22 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Alright guys, I've already started a thread about this and I'm sorry for littering but I have some serious shudders that happen intermitently (usually once every 3-4 times i drive). Every time it has done this I have been braking and below 5 mph. Tonight it happened on take off, I pressed the accelerator and it took it a while to respond then suddenly jolted up and shuttered (I'm positive this isn't axle wrap btw). I've thought about everything that could be going wrong, cv axles (driver side needs replacing, but this happened before the cv shit the bed), sway bar, uca, spindle, brakes etc etc. I am lifted but I dont know what other aspects that would affect. I'm happy to take any advice I just want this fixed, Thanks.
  2. Nov 5, 2010 at 5:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check the tranny fluid level.
  3. Nov 5, 2010 at 5:24 PM
    malander
    max
    01 limited trd 4x4
    will do, just out of curiosity how would that affect it?
  4. Nov 5, 2010 at 5:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If its low, it could be the tranny shuddering. Its free to check the level, and it will rule that out as a possability.
  5. Nov 5, 2010 at 5:38 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Have someone follow you around and eyeball it front/back as you try to recreate it. I am sure it will visually present itself.
  6. Nov 5, 2010 at 5:40 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    brake piston stuck? my old taco did that and veered left (driver side front piston was sticking).
  7. Nov 5, 2010 at 5:45 PM
    malander
    max
    01 limited trd 4x4
    did it veer left when braking? I've had that issue too that nothing has seemed to fix and then this problem developed. I'll try and look into it a little bit more
  8. Nov 5, 2010 at 5:45 PM
    malander
    max
    01 limited trd 4x4
    I had thought of somehow attaching a camera to something and drive it around but that aint gonna happen cuz im poor haha
  9. Nov 5, 2010 at 6:06 PM
    magikbean562
    greg
    socal
    pinto
    33" mudders
    yeah, it would shoot left when braking.
  10. Nov 5, 2010 at 6:08 PM
    magikbean562
    greg
    socal
    pinto
    33" mudders
  11. Nov 5, 2010 at 7:11 PM
    malander
    max
    01 limited trd 4x4
    Thanks alot guys I'll have to check everything out tomorrow when it's light out. I'll probably get my mechanic to look at everything after the cv install
  12. Nov 5, 2010 at 7:44 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    does your ABS or traction control light come on when it happens?
  13. Nov 5, 2010 at 8:46 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I hope this works out for you :)
  14. Nov 6, 2010 at 8:52 PM
    malander
    max
    01 limited trd 4x4
    checked the at oil and it seemed fine, it happened again today hopefully I can get everything figured out by monday and fixed the following week
