Extremely Bad Gas Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ddChuck, Jun 20, 2019.
  1. Jun 20, 2019 at 6:03 PM
    ddChuck
    ddChuck [OP] New Member
    Charlie
    2006 Toyota Tacoma
    What’s up guys, don’t post much at all on here but occasionally come on to look around.
    Anyway I have a 2006 Tacoma, 4 Door Prerunner 4.0L, and I’ve had it about a year. Got it as my first car, few months later engine light came up and head gasket was failing, water pump, etc.
    $5-6k later and it’s fixed but over the last few months I’ve gotten average of 11 MPG which is f**king insane for an 18 year old.
    Oil and filter is done, spark plugs new, entire top of the motor basically redone, fuel hasn’t been weird in the area, etc. Nothing comes to mind when it comes to what’s making my mileage suffer but I need something done.
    Does anyone have any suggestions? I don’t drive it crazy, but I drive it a lot. Stock wheels/suspension.
    Anyone with some knowledge of what could be making this happen, please help haha. Anything I need to check? things that go bad on Tacoma’s that will cause poor mpg?
    Thanks, much appreciated
  2. Jun 20, 2019 at 6:18 PM
    RoastyToastyMan
    RoastyToastyMan Well-Known Member
    Jayme
    2010 White Tacoma TRD Offroad
    What kind of tires? Have you checked to make sure you dont have a dragging brake? Any armour added? When the HG was replaced were the injectors checked?
  3. Jun 20, 2019 at 6:27 PM
    ddChuck
    Charlie
    2006 Toyota Tacoma
    Breaks fine, were done not to long ago. Again, stock wheels and rims with the 06 Tacoma.
    And yes, they basically checked the entire motor and put it through lots of testing before it was sent back to me.
  4. Jun 20, 2019 at 7:05 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Possibly bad or close to failing cats. O2 sensors. My 15 4.0L gets 22-23 mpgs with 80K miles. Is the air filter new? Clean your throttle body and mass airflow sensor. Don’t assume all that was done on the engine rebuild.
  5. Jun 20, 2019 at 7:14 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    OP, how did you calculate your mpg?
    Hobbs likes this.
  6. Jun 20, 2019 at 7:20 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  7. Jun 20, 2019 at 7:21 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, I would suggest that you get a scan tool on the thing and look at the short- and long-term fuel trims (STFT, LTFT) and see what they show. You may have excess air (small leak) or something else that may be revealed by the O2 sensors pointing toward bad cats, injectors, etc.
  8. Jun 20, 2019 at 7:24 PM
    NavyGuyAN
    NavyGuyAN Well-Known Member
    Virginia Beach, VA
    2010 Silver Taco 4x4
    Wet Okole Seat covers, Weathertech Floor mats, Blistein 5100's all-around, BFG KO2’s Fumoto Drain valve
    ARB1977
    How do you find out if your O2 sensor’s and cats are going bad? I have a 2010 and I get 15mpg
  9. Jun 20, 2019 at 7:52 PM
    RoastyToastyMan
    Jayme
    I've seen many people mention this but what are you looking for as far as fuel trims? What numbers are considered acceptable?
  10. Jun 20, 2019 at 8:40 PM
    reidkm
    reidkm Does lifting my truck increase my boto size?
    Reid
    Hilo, Hawaii
    2015 Tacoma, 4.0V6, 4x4 SB
    6" RC Lift Kit, Bilstein 5100 Full length shocks front and rear, OME 883 Coils, SPC UCA's, 285/70/17 Cooper STT Pro's
    I get 10 - 12 mpg with 33x12.5x20 and a 6" lift. Stock I was getting a consistent 18-20 mpg. Check your spark plugs, coils, spark wires, timing, TB, air filter, fuel filter, and ensure correct oil levels and what not. Make sure your tires are inflated correctly. Do you experience a power loss? If so, that may explain the bad mpg. Check your entire exhaust system as well and ensure you muffler and cat are in good shape. If your cat or header pipes are glowing you have a combustion issue. Happened to me once in my old 3.4 taco
  11. Jun 21, 2019 at 12:44 AM
    ddChuck
    Charlie
    2006 Toyota Tacoma
    Haven’t checked cats or 02 sensors, I cleaned MAF sensor few months ago throughly, was gonna get on the throttle body soon.
    Past 4-5 months I have been calculating every tank on how many gallons I’ve put in vs how far I’m able to drive. Simple stuff
    In an auto class, ran scan every month with a very high end device. No codes for anything whatsoever, it’s odd
    18-20 mpg would be a dream in my truck, I use it a lot and getting back into motocross so with this mpg, it makes me want to sell the damn thing. Near 5k deep in gas this year oof
    Thanks for the info I’ll check all that
  12. Jun 21, 2019 at 1:30 AM
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    Charlie,
    Where do you live? My commute is a lot of hills and then stop and go traffic so my mileage also sucks. It also doesn't help being young and hitting the throttle hard. Not to say you are a hoonigan, but it takes a while to learn how to drive mpg conscious.
  13. Jun 21, 2019 at 6:08 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Another thought - since the whole top end was R&R'd, it's also possible you have an issue with cam timing. That's an awful lot of mpg loss for it to be a small issue.
  14. Jun 21, 2019 at 6:29 AM
    Taco'09
    Here is quick and dirty and intended only to get you started:
    Basically what you are going to do is hook up the scan tool with the engine warmed up and watch for a minimum of about 30 seconds each the short- and long-term fuel trim values at idle, 1,500 rpm and 2,500 rpm.
    The STFT will be bouncing all over the place as it is constantly sending correction signals to the ECU but ideally you would like to see the numbers frequently flashing around 0 plus or minus 10%. So you will see things like +4, -1, -1,+2, 0, +1, -8, 0, +10, -3, -10, -1, +1, 0, -1, -2, and on and on.
    The LTFT is the accumulation of all these rapidly changing values of the STFT and will show a a more stable number not rapidly dancing all over the place, but again ideally you would like to see the LTFT around 0 plus or minus say 5-10%, but the closer to zero the better.
    And finally you want to know the Total Fuel Trim. Add the STFT and LTFT numbers to get the Total Fuel Trim. If the STFT is +2% and the LTFT is +4% that would be a total of +6% again near 0 is good. But watch the signs, if the LTFT is +10% and the STFT is -8% the total fuel trim is actually +2%.
    Here is a much more thorough discussion and a good place to start understanding this on our trucks: https://www.tacomaworld.com/threads/understanding-o2-signals-and-fuel-trim.259164/
