Extremely poor mpg's! Ideas please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1one1, Apr 10, 2012.
  1. Apr 10, 2012 at 1:14 AM
    1one1
    1one1 [OP] addicted...
    Keone
    Eastside Oahu
    2006 DCSB Sport 4x4
    blk headlights, 6k hid's, blk grillcraft top n bottom, led taillights w/ smoked reverse, blk wet okoles, extang trifold cover, 265/70 duratracs, bilstien 5100 @ 2.5, 1.5" aal rear, spidertrax 1.25" wheel spacers, super white led interior lights, 2 JL 10" subs in custom box, alpine m-1000 amp, Pioneer 3200dvd head unit, husky floor liners, more to come...
    Extremely poor mpg's in my dads 2006 4.0 v6 at taco. 52k miles
    He has been complaining about poor gas mileage for awhile so I decided to check it out. I filled it up and drove normally for the full tank and did the math. If the gauges are reading correctly the truck is only getting about 13-14 mpg's!
    It has billies set at 2.5 and 265/70/17 duratracs. I know this affects mpg's but this seems a bit extreme. I've also noticed that the power seems a bit sluggish and when going down hill when the truck should be picking up speed based on momentum it seems like its being slowed by something.
    Wondering if anyone on her has any ideas or suggestions on what could be causing this or possible solutions. Someone recommended a trans flush and trans filter service but I'm wondering if that could be it.
    PLEASE HELP!!!! Thanks guys
  2. Apr 10, 2012 at 1:16 AM
    1one1
    Keone
    Eastside Oahu
    2006 DCSB Sport 4x4
    Btw I have already checked the brakes and they are operating normally.
  3. Apr 10, 2012 at 1:36 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Those tire changes might effect MPG 1mpg if not calibrated correctly. Lift might take another due to wind resistance... I get 17.1 average mpg in my DCSB, so that's about where you would be at...
    Check tire pressure with the chalk test. Baby the accelerator. Check MAF Sensor...may need to be cleaned. Air filter might need to be replaced.
    Maybe diff fluid change...I'd guess that before tranny flush...especially with the 4x4.
  4. Apr 10, 2012 at 1:41 AM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    If it feels as though its dragging (slowing without known cause) check the parking brake. I just did that exact fix on my buds ford yesterday. His gas mileage went to **** and he said it was slowing down excessively for no reason. I had him drive it over to me, first thing I did was walk back and feel the rear brakes and they were hot. The cable was looser than it should have been and thus got hung up when he released the pedal causing the brakes to drag.
    Note* I have billies set at 0 with 886s now, front plate bumper, and canopy. Still getting about 17 depending on if my right foot is feeling heavy or not
  5. Apr 10, 2012 at 1:41 AM
    1one1
    Keone
    Eastside Oahu
    2006 DCSB Sport 4x4
    He checks tire pressure religiously and the air filter was changed recently. Haven't checked maf or diff. I don't think it's the lift or tires I have friends with the same truck with 6" of lift and 35's that are getting better milage.
  6. Apr 10, 2012 at 1:45 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Yeah, thats why I would think MAF or Diff...
    Are the Duratrac's Load range "D" or "E"? "E" are much heavier and will drop MPG...
  7. Apr 10, 2012 at 1:49 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    With this, I would check a minimum of 3 tanks and take the average. Topping it off can make the difference of 14 mpg and 22mpg, depending on the pump. Didi you use the same exact pump and let it stop itself at full to get the most accurate reading...?
  8. Apr 10, 2012 at 2:27 AM
    1one1
    Keone
    Eastside Oahu
    2006 DCSB Sport 4x4
    I'll try that tomorrow hitman. As far as the gas pump thing I didn't get that scientific about it... YET. I think I might have to though.
    As far as the parking brake goes wouldn't I smell some kind of burning smell if the brake was engaged and I was driving with it that way? I would think even if it was just slightly grabbing there would be some kind of smell and or squealing.
  9. Apr 10, 2012 at 3:19 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Maybe it needs a tuneup? When's the last time the plugs were changed?
  10. Apr 10, 2012 at 3:29 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    You also have to consider where you are driving. Around town 13-14 are about average, freeway 17-20
  11. Apr 10, 2012 at 9:50 AM
    hitmans.army
    Myrtle Creek, OR
    You *should* smell brakes if they are dragging. On my buds, you couldn't until you were right at the wheel. Stranger things have happened.
  12. Apr 10, 2012 at 10:04 AM
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    Agreed
  13. Apr 10, 2012 at 10:06 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    The tires make the biggest difference based solely on the larger circumference. The larger wheel wont turn over as many times as a smaller one and the odometer will think you're getting worse mileage than you really are.
  14. Apr 10, 2012 at 10:19 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Not another MPG thread.
    Those tires and lift affect it. Regular maintance. Synthetics. Premium gas. No AC.
    I get about 19.5-20mpg avg.
  15. Apr 10, 2012 at 10:30 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    My truck is an AC and not a DC, same Duratrac tires but 265/75/16, i use synthetics, Billies set at 1.75, 89 octane gas, new plugs, diff. and gear box fluids changed, aFe Pro Dry filter, 37K miles.........I only get 14.5 MPG. I blame it on the ethanol.
  16. Apr 10, 2012 at 10:31 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Plugs should be changed soon, same with the diff oil. That'll buy you at least 1-2 mpgs. Second it feels like it's dragging from negative compression in the engine. It's just the way it's built. Mine does it too.
    3rd, your county might still be on winter gas. That'll get you another 1-3mpg. I know it did in mine.
    Duratracs in that size shouldn't kill the mileage that much if at all.
  17. Apr 10, 2012 at 10:32 AM
    Thundjet
    Thundjet Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    If your dads truck is just running around town with no short freeway trips then his mileage is in the ball park.
  18. Apr 10, 2012 at 10:46 AM
    1one1
    Keone
    Eastside Oahu
    2006 DCSB Sport 4x4
    Sounds like alot of you are saying these numbers could be par for the truck. If some of the suggestions don't solve anything it might be goodbye to the taco. Gas is $4.49 here in Hawaii and steadily going up.
    Thank all of you for your input. I will try a few of these suggestions in hope that they will help. Aloha...
  19. Apr 10, 2012 at 10:48 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Also, go easier on the skinny pedal. Sounds easy but a lot of people don't realize driving habits can account for something retarded like 30-40% of poor fuel consumption.
  20. Apr 10, 2012 at 11:55 AM
    ItalynStylion
    Steven
    DFW, Tx.
    It's true. The single best thing you can do to alter fuel consumption is to not drive like an ass hat.
