Eye-to-Stem Rear Shock Adapters
Discussion in 'Hawaii' started by cubiclesurfer, May 6, 2016.
  1. May 6, 2016 at 12:25 PM
    cubiclesurfer
    cubiclesurfer [OP] Well-Known Member
    Kailua-Kona, HI
    I've been searching for rear shocks for a while now, and I was wondering if anyone has any input on the eye-to-stem shock adapters? Basically, this:
    http://www.amazon.com/dp/B002SJBXPC/ref=wl_it_dp_o_pC_nS_ttl
    Running something like this would open up a whole bunch of shock options, without having to do a shock relocation, which I don't have the time or skills for :pout:
    I believe running something like this would add an inch (length supplied in the Q&A section) to both the collapsed and extended lengths. a couple options that might be usable are either the 9" 5125 (15.11" coll/24.35" ext) or the 9.8" 5165 (14.6" coll/24.4" ext) - add 1" to the numbers for the adapter.
    As far as the non-adapter options, the cheapest route is to just go with the RCD 5100's (16.34" coll/27.28" ext) which doesn't require the adapter, but does have a pretty long shock body. Or spend a little more and get the Icon 56503/56503R-EXT shocks, but I thought someone mentioned that extended length shocks aren't warrantied or something?
    what do you guys think? I'm confused... :goingcrazy:
  2. May 6, 2016 at 1:06 PM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    Jus get the rcd 5100s
    cubiclesurfer [OP] likes this.
  3. May 6, 2016 at 2:13 PM
    cubiclesurfer
    Kailua-Kona, HI
    you're bias and you get way more lift than me! lol
    although, I did find this a few days ago:
    https://www.tacomaworld.com/threads...0s-f4-be5-b110-t5.217071/page-3#post-11412707
    dakars w/ the top overload removed, AP flip kit & superbumps, but with 255/85's - pretty similar setup as mines. I pm'd him and he said so far it's worked out for him.
    @deeezy - was it you who mentioned the extended travel icon warranty? who else runs extended icons?
  4. May 6, 2016 at 2:40 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Yup, anything other than their stock replacement length shocks, there is no warranty. It is then classified as a "custom" built shock. If you check, most vendors have a disclaimer for these extended length shocks that mention the non-warranty. I'm not positive that this is for any other brand than Icon. I would check with the vendors to see if the other brands (King or Fox's) extended travel shocks are non warranty too.
  5. May 6, 2016 at 2:50 PM
    cubiclesurfer
    Kailua-Kona, HI
    oh ok, so yours are custom length, or the 56503-EXT?
  6. May 6, 2016 at 3:44 PM
    deeezy
    Dana
    Hawaii
    Yes, the extended ones from Wheeler's.
