F.S 1991 Nissan Sentra SE-R
Discussion in 'Arizona' started by Deltabox, Jun 5, 2011.
  1. Jun 5, 2011 at 5:35 PM
    Deltabox
    Deltabox [OP] himmie's Other Half
    Nathan
    AZ-WI
    04 4runner 4wd
    Looking to get rid of my Sentra as down payment for a tacoma.
    It's currently at 202k miles. Exterior needs some work and it does not have a/c, but otherwise a great car.
    Motor is an 01' sr20ve. Has around 30k miles on it. Runs off a fully tuned Jwt ecu. Has a Vq maf. Asp header ment for the ve. Apex-i exhaust. Walboro 255lph fuel pump. greddy mss to control the vvl engagement. Made 184whp in Florida on this set up.
    Trans is out of a 94 se-r. 4.47 final drive LSD. Has a 8lb Jwt flywheel. Act stage 1 pressure plate, and a 06 spec v clutch. Good for 300whp. Does Not have 5th pop out issue. And will never have it being the trans is a 94.
    Suspension wise its sitting on Kyb agx struts that are 4 way adjustable front and 8 way rear. Gab ground control springs for ride height adjustment. Has nx2000 rims in white. Rear tires were wearing before I did an alignment. Need new soon. Fronts are ok. Has goodridge steel braded brake lines.
    Interior is almost mint. Even the dash. All was pulled from the 94 ser parts car. Has a Nissan GTI-R steering wheel. And a rare discontinued nismo shift knob.
    Exterior needs paint. Has a Nissan sunny grill. Custom fiberglass hood used on Greg v's race se-r.
    The car has roll up windows. And no sunroof. That with the ac delete brought the weight down to just under 2200lbs. That with over 210 crank HP is mean. Ran a 13.8 @ 103 at bradenton motorsports park in south Florida a little over a year ago after it was built.
    Ok so issues.
    Passenger window is a little weird to roll up.
    Needs paint
    Some of the rims are lightly curbed.
    No ac or heat or anything.
    Rear tires needed eventually.
    Front ebc pads are going to need replacement soon
    No washer bottle.
    That's all i can think of. I'm being overly picky about it.
    Well despite the lack of ac. It's a 13 second all motor ser that still gets 30mpg. And the proceeds go to a good cause. My new 4x4 trd off-road. ;-)
    Asking 3500 or best cash offer.
    623 256 8256 -Nathan
    text ok.
    I'm posting this from my phone. Will have pics up soon. Thanks.
    Here you go..
  2. Jun 5, 2011 at 5:37 PM
    Deltabox
    Nathan
    AZ-WI
    04 4runner 4wd
    Edit. My avatar is my Sentra with the old rims. So you can get an idea
  3. Jun 5, 2011 at 5:38 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    pictures are needed per forum rules even if it is in your avatar. people needs to see what they are buying :)
    welcome and glws
  4. Jun 5, 2011 at 5:46 PM
    Deltabox
    Nathan
    AZ-WI
    04 4runner 4wd
    Thanks.
    And pics will be up in about an hour or so. Have to get back to the computer at home. Just posted up the ad now wile I was sitting at the vet waiting for over an hour...heh
  5. Jun 5, 2011 at 5:53 PM
    08pretaco
    Oliver
    az
    for sure!
    whats wrong with your pet? most people dont go to the vet on sundays?!
  6. Jun 5, 2011 at 6:20 PM
    Freelance
    Freelance Well-Known Member
    Curtis
    Las Vegas, NV
    07 DC PreRunner SR5
    GLWS! I loved my Nissan, it was my first "tuner" car. 200SX-SER with a perfect FF SR20DET swap. 339hp at the front wheels, under 13psi. With stock suspension, that bad boy would break the fronts loose on the highway at WOT in 4th. Loved that car, until it made friends with the back of a Jeep.
    Again, good luck with the sale brother!
  7. Jun 5, 2011 at 6:43 PM
    Deltabox
    Nathan
    AZ-WI
    04 4runner 4wd
    He has kennel cough, from county. Just needed to get him some med's. He is ok otherwise.
  8. Jun 5, 2011 at 6:45 PM
    Deltabox
    Nathan
    AZ-WI
    04 4runner 4wd
    Ouch. Yeah DET Sentra's are also mean. But being mine is NA with traction issues in 1st and 2nd from a roll i could only imagine over 300hp. :rolleyes:
  9. Jun 5, 2011 at 6:47 PM
    08pretaco
    Oliver
    az
    glad thats all!
  10. Jun 5, 2011 at 6:50 PM
    himmie
    himmie Well-Known Member
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    Yes, me too. The fur kid has a had a rough week already. But, at least he is out of county and won't be euthanized...
    Anyway, back to getting the Sentra out of my garage... :rolleyes:
  11. Jun 5, 2011 at 6:51 PM
    Freelance
    Curtis
    Las Vegas, NV
    07 DC PreRunner SR5
    Yea man, and with stock wheels and suspension the thing would never hook up. However, from a roll in 3rd the thing was just retarded. Ended up with the sleeper look because I blew all my money on boost. Looking back, I can probably count on one hand the number of times I could launch without slipping all the way through 1st and 2nd. Still enough balls to smash some local C6's and 5.0's though!
