Fab tips: Mounting rear 8" shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vegabeltran, May 28, 2015.
  1. May 28, 2015 at 9:20 PM
    Vegabeltran
    Vegabeltran [OP] Well-Known Member
    David
    San Diego
    06 PreRunner SR5 TRD
    TRD Intake, DSM Midtravel w/Fox 2.5 Coilover, Bolt On Bedcage w/ Fox 2.5x14, OMD LeafSprings, MaxTrac Spindles, 4.56 Gears
    Hey guys. I wanted to mount 8" shocks in the rear and came across curiosities.
    1. I'll need to fab a new mount to run them instead of the OEM mounts..any fab guys have tips where to mount at? Or if it's even possible to fab in the shock mounts.
    2. Are the shocks too long/long enough to run?
  2. May 28, 2015 at 9:28 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You can run 10" shocks in the stock location. Mine are 16" coll, 26" ext. in the stock mounts.
  3. May 28, 2015 at 9:29 PM
    Vegabeltran
    David
    San Diego
    Do you still run the stock lowers on the axle as well?
  4. May 28, 2015 at 9:35 PM
    deeezy
    Dana
    Hawaii
  5. May 29, 2015 at 12:38 AM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    Same here. Icon 2.5s that are 10.3" travel. Stock mounts (required minor grinding on the lower shock mount), using OME Dakar springs, all pro u bolt flip kit with wheelers super bumps.
