Fabricating a Bed Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OutbackHack, Feb 27, 2013.
  1. Feb 27, 2013 at 12:03 PM
    OutbackHack
    OutbackHack [OP] Well-Known Member
    Golden, CO
    2014 DCLB Heavy
    About to start fabricating a bed rack for bikes, kayaks, maybe an RTT down the road, etc. Based my design on a bunch of members' racks and it seems like a good idea. I'd appreciate any feedback before I start cutting metal.
  2. Feb 27, 2013 at 12:14 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If I were to build a bed rack and had plans for a RTT, I would make the top of the rack lower than the top of the cab so the top of the tent when collapsed would be level with the top of the cab. That would make it better for long trips (less drag and wind noise). But, if you need the cargo space, that's a decision you'll have to make. Just my $0.02. I like the idea!
  3. Feb 27, 2013 at 1:06 PM
    OutbackHack
    Golden, CO
    2014 DCLB Heavy
    Good Point. My current design is a bit of compromise, 15" (instead of 16" in the latest drawing) would still let me see out the back and give just enough room for a 33" tire to be rolled in vertically. The top of the rack should be 3-4" below the cab roof line, so only 2/3 of a RTT would stick up in the wind. It should be just high enough that I can get a canoe or kayak to clear the roof with some sort of mount, and let me almost stand up under the RTT awning when open.
  4. Feb 27, 2013 at 5:24 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    The trouble is - it's hard to get it low enough to matter and at the same time, keep the tent high enough to use an annex, or have sufficient access to cargo space.
    Truth told, the RTT didn't have that great an effect on my MPG - if you have enough of a gap between it and the cab, it's not a huge drag. I lost far more MPG going with an aggressive-ish tire (BFG AT KO) and a lift.
    In my view, the main trouble with having the RTT up that high is bugs. I installed a roof rack and a fairing to resolve that problem.
  5. Feb 27, 2013 at 5:37 PM
    kai38`
    kai38` Well-Known Member
    Good looking rack, I'm having one built now to carry my RTT.
    I have a AutoHome Columbus http://www.autohomeus.com/rooftop/columbus.php
    that is longer then my short bed, I don't want a 2ft overhang on the rear so the rack is being made a little taller the the roof so I can extend it 1-1.5 ft over the cab.
    You might think about adding rear & side light mounts and antenna mounts for future CB or HAM install
  6. Feb 27, 2013 at 5:46 PM
    Pugga
    Massachusetts
    That's a good idea with the fairing. :thumbsup:
  7. Feb 27, 2013 at 5:55 PM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
    Works, too!
    See ma! No bugs!!!
  8. Feb 27, 2013 at 6:01 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Looking good. I'd like to see how this turns out.
  9. Feb 27, 2013 at 8:51 PM
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    What rack is this RTT on?
    Please keep us posted, I love your ideas for a rack.
    E-Paz 732NJ likes this.
  10. Feb 27, 2013 at 9:05 PM
    Spoonman
    Jamie
    Alberta
    Looks like a Thule type rack. You can see the bikes are mounted on the same bars as the tent.
  11. Feb 27, 2013 at 9:07 PM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    Nice design man. I'm looking to have one built and have been doing like you....browsing other designs and integrating ideas from different racks into my design.
  12. Mar 14, 2013 at 3:36 PM
    OutbackHack
    Golden, CO
    2014 DCLB Heavy
    Picked it up from the fabricator today. Happy with how it turned out. Only thing I would change so far if I was doing it again would be to make it an inch shorter. Now it just needs to warm up so I can clean it up and paint it.
  13. Mar 14, 2013 at 3:44 PM
    medic2230
    Murph
    Bama! Roll Tide
    Looks good!!! :thumbsup:
    Don't forget to put some cap foam between the bedside and the rack so it doesn't mess up the plastic caps.
  14. Mar 14, 2013 at 3:45 PM
    kai38`
    What are the 1x1 pieces sticking out on the side for?
    Never mind I scrolled up and saw the plans for bike mounts.
  15. Mar 15, 2013 at 4:50 AM
    OutbackHack
    Golden, CO
    2014 DCLB Heavy
    I think I'm going to take some cues from this approach:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/143789-bed-rack-idea.html#post3390818
    and just ditch the plastic caps completely. Should make the rack sit almost an inch lower (which is a good thing) and I can just snap the caps back on when I remove the rack.
  16. Mar 15, 2013 at 8:07 PM
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    That looks really good; good job!
  17. Mar 26, 2013 at 10:25 AM
    OutbackHack
    Golden, CO
    2014 DCLB Heavy
    Cleaned it up, drilled some mounting holes to bolt it into the bed rails, and threw a few coats of bedliner on it. Ended up removing the plastic bedside caps to get the rack to sit lower. Covered the tops of the bedsides with 3m vinyl wrap and put some weatherstripping-type foam on the underside of the rack. Hopefully that'll keep things protected, but I'll pull it off in a week or two to see if anything is wearing through. It's bolted down pretty solid though, so shouldn't be too much friction from movement.
    Thinking of mounting the spare (which doesn't fit well in the stock location anymore) upright in the rear-left corner of the bed.
  18. Mar 26, 2013 at 10:29 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    NICELY DONE!!!
  19. Mar 26, 2013 at 8:42 PM
    kbraunphoto
    kbraunphoto mountain bike haulin' & off camping
    Kevin
    Atlanta, GA
    '15 Inferno Orange TRD Pro
    Just a few expensive & DIY things...
    Nice,
    Can you take closer photos from the rear in relation to the distance the bike racks stick out from the truck?
    I'm doing the exact same thing and was working on how to mount them.
    Have Yakima stuff as well...
  20. Mar 29, 2013 at 9:29 AM
    OutbackHack
    Golden, CO
    2014 DCLB Heavy
    Don't know if this helps. The mounting arms I'm using are 1" square hollow steel and extend around 4" past the top of the bedside at the front. The front and back are the same length, but because the bedside is narrower towards the rear, they have a bit more clearance back there.
