factory 2010 radio no am reception
Discussion in 'Audio & Video' started by aptech, Jun 17, 2012.
  1. Jun 17, 2012 at 7:02 AM
    aptech
    aptech [OP] Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    what are the most common things for the am radio to go out. i have factory 2010 dc offroad trd radio with cd changer i searched but didnt find a tread for it. thanks for the info.
  2. Jun 18, 2012 at 6:55 AM
    CrutchfieldDarren
    CrutchfieldDarren Well-Known Member Vendor
    Darren
    There is a few things that can affect AM reception. First and foremost is the way the antenna is mounted on the fender. At the base of the antenna it must bite into the underside of the fender to get a good ground plane.
    Most commonly I have encountered this on vehicles that were recently painted or had collision repair. It's not uncommon for the body shop to remove the antenna, paint the fender, some of the paint gets through the hole, then when the antenna is re-mounted it does not ground properly.
    This can also be a sign of a bad antenna coax. Specifically the outer shield of the cable. AM does depend on getting the signal on the center conductor of the cable and the outer shield of the cable.
    This could also be a sign of a bad radio, but if you are still receiving FM the chances of this are unlikely.
    Hope this helps you narrow it down!
  3. Jun 18, 2012 at 7:11 AM
    aptech
    houston
    10 dc offroad
    thanks ill start digging. an other note is that i hear engine noise sometimes also. would that point more towards bad antenna grounding?
  4. Jun 18, 2012 at 7:36 AM
    CrutchfieldDarren
    Darren
    Yes it most certainly does, this generally indicates a bad antenna ground as well!
    Have you had any body work on the truck recently?
  5. Jun 18, 2012 at 7:44 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Huh. Learn something new every day. Thanks Darren!
  6. Jun 18, 2012 at 8:33 AM
    aptech
    houston
    10 dc offroad
    had ghost flames painted . they broke the antenna nut getting it off so i put a washer and used the nut as a bushing.and screwed the antenna back on. it has a ground wire at the bottom of the mast. does it still need the ground at the finder?
  7. Jun 18, 2012 at 8:40 AM
    babytruck
    NorCal
    We use it for continuous news and sports.
  8. Jun 18, 2012 at 8:48 AM
    aptech
    houston
    10 dc offroad
    yap and fishing reports for the early morning sickos :D
  9. Jun 18, 2012 at 8:57 AM
    babytruck
    NorCal
    Didn't know sarcasm meters were still being used.
  10. Jun 18, 2012 at 9:02 AM
    aptech
    houston
    10 dc offroad
