Factory Fill Power Steering Fluid - 2015 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DallasTX, Feb 26, 2017.
  1. Feb 26, 2017 at 9:02 AM
    DallasTX
    DallasTX [OP] Well-Known Member
    2015 4x4 AC
    What type of power steering fluid is used for factory fill? I bought a used 2015 last week with a little over 13,000 miles and the power steering fluid is clear to yellow with a light brown tint.
    The owner's manual calls for Dextron II or III. Does Dextron come in a clear version? All Dextron that I have ever used has been red in color.
  2. Feb 26, 2017 at 9:06 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    It's basically Dexron III without the red dye in it. You too can purchase Dexron III without the red dye if your name is Toyoda and order by the truckload. ;)
    TomTwo, Mush Mouse, ABNFDC and 2 others like this.
  3. Feb 26, 2017 at 9:26 AM
    DallasTX
    2015 4x4 AC
    Thanks. Guess I will stick with the quarts since I do not need a truck load.
  4. Feb 26, 2017 at 10:10 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Yep - I've never seen it packaged for the individual users.
  5. Feb 26, 2017 at 10:12 AM
    KenLyns
    Belly of the Beast
    You don't actually need to change the fluid until 40-50k. :) I bought a quart of Toyota-branded D3 from the dealer. The power steering system uses very little fluid - less than 1/4 of the bottle. Used another 1/4 bottle replacing the fluid in my Subaru.
  6. Feb 26, 2017 at 1:50 PM
    DallasTX
    2015 4x4 AC
    Thank you for the feedback. It just caught my attention because it is not the typical red ATF.
  7. Feb 26, 2017 at 1:53 PM
    Bishop84
    Bishop84 Well-Known Member
    It's just not dyed from the factory, I've asked a few Toyota reps/engs about it.
    Any true ATF is a better detergent anyways.
    Dex3 works the GM clear/yellow stuff is incorrect.
  8. Feb 26, 2017 at 1:56 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    should look like Crisco oil, At 13k miles that stuff is still new, I would change it at the 30k miles maint. intervals, you can suck it out with a turkey baster a few times and refill till its clean, I ran a quart of maxlife thru mine its 90% new/clean. I used Valvoline max life ATF most people use it.
  9. Feb 26, 2017 at 4:26 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    Turkey baster method works great and unless there is an easier method, will continue to do this way.
  10. Feb 26, 2017 at 4:32 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I removed the return line and extended to a drain bucket. Then jacked up the front and manually turned front wheels to empty reservoir. Was a very easy and thorough way to flush the fluid.
  11. Feb 26, 2017 at 4:35 PM
    TacoCat
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    Probably gets more out too. I wonder does letting it drain completely hurt the pump, similar to the master cylinder? Might have to try that method next time.
  12. Feb 26, 2017 at 4:39 PM
    Mush Mouse
    mush
    2013 SR5
    me too, don't want the mess with flushing the lines this way does an adequate job done regularly
  13. Feb 26, 2017 at 4:54 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I'm normally in the turkey baster or partial change camp(brakes, transmission, radiator), but the complete power steering flush/replacement is maybe a 45 minute job and that includes jacking the truck up. That and the fill for my PS reservoir is too small for any normal turkey baster without modifying it.
    I did it a couple years ago with Valvoline Max Life. Easy as heck to do.
    Edit: Used this method-https://www.tacomaworld.com/threads/power-steering-flush.416379/
    Micbt25 likes this.
  14. Feb 26, 2017 at 5:02 PM
    fla_sun
    The pump is not running so can't see how it would hurt. The fluid container did go dry occasionally but always primed back up when more fluid added.
    I used two quarts total for a thorough flush.
    07 sport 4x4 and TacoCat[QUOTED] like this.
  15. Feb 26, 2017 at 7:46 PM
    KenLyns
    Belly of the Beast
    This is true! I ended up using a suction gun with 1/4" fuel hose to suck out the fluid from the reservoir. I bought the suction gun earlier for filling the transmission, so no extra cost incurred.
    TacoCat likes this.
  16. May 29, 2022 at 3:55 PM
    jhu23456
    jhu23456 New Member
    Jim
    ToyNebie
    zero
    I am not putting Red ATF fluid in my Power Steering.
    I like that it is clear and can readily see if old/dirty.
    Used clear Valvoline Maxlife Power Steering fluid Part No. VV335.
    I like that is has additives to protect/heal wore seals. Downside: It's not a Synthetic.
    Has anyone used Prestone "Asian" Synthetic Power Steering Fluid? It is available at Walmart.
    https://www.walmart.com/ip/Prestone...les-12-oz/35764368?fulfillmentIntent=In-store
  17. May 29, 2022 at 9:28 PM
    TacoTuesday1
    SoCal
    I use M1 ATF
    I could easily use steering hydraulic fluid but I believe M1 ATF falls within the approved list.
    Red ATF is clear.
    Automotive manufacturers switched to synthetic for less pump cavitation, no longer selling old mineral-based fluids.
    I believe their synthetics are reverse-compatible and the part numbers supercede to replace old mineral.
    Yet you went out of your way to find mineral. Nice!
    Wait until you find out what ATF does in a vehicle (applies pressure, lubricates, is pumped)
    I don't put WalMart products in my vehicle
  18. Jun 1, 2022 at 2:16 AM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    Just changed my PSP and re-filled with... SuperTech Dexron III bright red tranny fluid! :anonymous:
    Nothing's blowed up or fallen apart yet! :rofl: Doing the flush beforehand was way easier than I anticipated and I plan on making it part of the regular maintenance.
    A couple of things I did that made the PSP swap easier: Undid the air intake to make it easier to access from the top and undid the swaybar bushing bolts to get the pump out from the bottom...
  19. Jun 1, 2022 at 6:59 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    This method is so easy, I do it nearly every year. I just did both our trucks the other day and found, especially on the 2006, that when I flush with this method, the first few turns of the wheel yield the darkest fluid. Turkey baster method might be fine for some, but I'm convinced the added steps of pulling the return line, capping the reservoir, jacking up the front end and turning the wheels produces the most complete flush of the system.
    I've been running Valvoline MaxLife ATF since all the way back to my 1st gen and flushing this way without problems. Cheap, available at Wally World and when the red fluid gets darker in the reservoir, I change it.
    Micbt25 and hoffengineering like this.
  20. Jun 1, 2022 at 7:43 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    I just used Valvoline maxlife tranny fluid.
