Factory heated seat switch w/ aftermarket heaters/elements?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xjoey dubsx, Jan 22, 2016.
  1. Jan 23, 2019 at 2:24 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Is it possible to use aftermarket heating elements and hook it up to the OEM wiring under the seat??
  2. Jan 23, 2019 at 4:27 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I did not use factory switches or wiring because: The OEM switches are low amp. I think in the 3a range and the aftermarket heaters run 10a up into the switches they provide. You would need to have a relay set up to make it work safely. I also wanted heat to all four seats...
    tbird95 likes this.
  3. Jan 23, 2019 at 11:32 AM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
