Factory Microphone in Aftermarket deck?
Discussion in 'Audio & Video' started by JCVorndran, Jun 5, 2012.
  1. Jun 5, 2012 at 6:43 PM
    JCVorndran
    JCVorndran [OP] Macaroni Connoisseur
    Jonathan
    Phoenix
    6000K headlights and foglights, limo tint, Pioneer AVH8400, Rockford T1652 components, PBR300.1 and PBR300.4
    Hello all, I am new here as of last week! I searched through the forum but still have not found a definitive answer. Is it possible to hook up an aftermarket headunit say a pioneer AVH-8400 double din to the factory microphone and bluetooth settings. I just purchased a 2012 Double Cab, its not a JBL system just the basic one, but I really do not want to lose the factory microphone and have to install a new one after the fact. I have not taken the dash apart yet as I am still waiting on Metra or Scoche to come out with the dash kit etc.. So if someone who has experience could please let me know if it is possible that would be great.
    Thanks
    Jon
  2. Jun 6, 2012 at 8:32 AM
    zphly
    zphly Active Member
    DC
    '12 TX Pro
    Sub'd. Interested in compatibility of a 2012 OEM bluetooth mic with an aftermarket headunit too.
  3. Jun 18, 2012 at 1:09 PM
    JCVorndran
    Jonathan
    Phoenix
  4. Jun 18, 2012 at 1:33 PM
    BaconTaco
    BaconTaco Well-Known Member
    Nate
    Lancaster, CA
    06 DCSB TRD Sport silver prerunner
    secondary & Res Box delete, Kenwood DDX419 HU installed in metra 95-8214 and Xbox 360, Mobil 1 syn oil, Shortened stock antenna, 400w anytime mod with rear center console outlet, Debadged tailgate, tailgate anti theft clamp mod, immryo's rear view mirror re locator, post axle exhaust dump, Black TRD OR floor mats, TRD center caps, 265/70/17 BFG rugged terrains
    Usually most manufacturers use a proprietary mic that only works with their HU. I found that out when I tried to upgrade the mic for my kenwood. It's not like a standard mic that plugs into a computer.
    But with that said, you're going to have to do some research. You may get lucky. Some mics are the same. In my case I found that I could use a parrot mic for my kenwood because they actually manufacture the kenwood mics. You might find that Toyota uses JVC for example. You'll need to locate your plug for the mic and try to match it up with an aftermarket mic and then go from there. Or see if there's an adapter to use the stock mic from Tacoma.
  5. Jun 18, 2012 at 2:07 PM
    JCVorndran
    Jonathan
    Phoenix
    Thanks for the suggestion, I was just hoping that the linked forum would have helped to see if anyone has tried that. They tapped into the mic harness and then soldered on a regular microphone jack for aftermarket head units. Conceptually it seems like it should work, I am just new to the Tacomas and was not sure if there was anything I might be missing.
  6. Dec 13, 2013 at 8:30 AM
    2013TacoLTD
    2013TacoLTD Well-Known Member
    Dennis
    Mckinney, TX
    13 Tacoma Limited V6 4X2
    Radio On Mod, Complete new stereo with 10" subs, Truxedo bed cover, GT-MAT through doors and rear cab.
    Did it work?
  7. Jan 3, 2014 at 7:12 AM
    JCVorndran
    Jonathan
    Phoenix
    I was not able to get it to work, but I have a really limited skill set for this kind of mod
  8. Jan 3, 2014 at 8:26 AM
    tony7758
    tony7758 Member
    Tony
    Pearland, Texas
    2012 4WD TRD OR
    I have the 2012 double cab without the JBL also. I just put a Kenwood DNN990HD in my Tacoma last week so I have looked into this. The factory mic is a 6 Volt powered mic. Your rear camera is a 6 Volt camera also. I did not use the factory mic as the Kenwood has a 2 wire (non powered) microphone input. I do not know what microphone your new head unit has. I connected up the Aux & USB in the lower dash to the Kenwood too. I signed up for the Toyota TIS subscription for a weekend. It will give you all the info you need to do this and more. That was the best idea I found looking into this. I downloaded and saved all the info for my truck, not just the stereo info. I got an extra day as I signed up for the weekend. It is only 10 or 15 bucks and damn well worth it! Be ready to spend several hours on the TIS site. You can PM me if you have any other questions.
    Tony
  9. Jan 15, 2014 at 7:34 AM
    Piratelawyer
    Piratelawyer Member
    North Carolina
    12 TRD Double Cab
    I sent you a PM with some questions.
  10. Dec 14, 2019 at 9:44 AM
    travisklein
    travisklein New Member
    travis
    Any way to not keep this a secret and just say which of the 4 wires of the powered mic you used to or how you did it? I'm not asking for schematic diagram of your vehicle that you got from TIS. I don't even have the car you have but I do have a toyota with powered mic and trying to figure out which wires are which.
    thanks
  11. Dec 14, 2019 at 9:47 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
  12. Dec 14, 2019 at 1:15 PM
    travisklein
    travis
    thank you alot, still lost though lol we'll see if that thread can help
