Factory Oil and Tranny Cooler
Discussion in 'Towing' started by Bamban, Aug 21, 2008.
  1. Aug 21, 2008 at 7:37 PM
    Bamban
    Bamban [OP] Active Member
    Central TX
    08 Double Cab 4x4 SB 4.0L
    TRD Cat back, TRD codl air induction,
    I have an 08 4x4 DC 4.0L Taco that I am trying to fix up to my liking. Though I may not be towing any time soon I do like the thought on having an oil and tranny cooler, but I am not a great fan of after market stuff.
    Do you folks know if the factory parts - coolers, fittings, etc are available and where?
    Thanks in advance for your help.
  2. Aug 22, 2008 at 7:06 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Available... Yes.
    Available at a reasonable price... NO.
    an after market tranny cooler is for all intents and purposes exactly what you'd get from the dealer as well. So for that aspect just pick the biggest B&M trans cooler you can find and hook it up. The oil cooler is another matter, and realistically unless you are going to be towing up and down mountains every day in over 100 degree heat it is not really necessary, for the roughly thousand bucks it would cost you for the part and to have it installed.
  3. Aug 22, 2008 at 9:48 PM
    Bamban
    Central TX
    thank you for the reality check
