Factory rake after 3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sport2012, Mar 20, 2013.
  1. Mar 20, 2013 at 10:35 PM
    Sport2012
    Sport2012 [OP] Thin Blue Line
    NJ
    12 TRD Sport DCSB 4x4
    Tint, EGR In Channel visors, Access-Lorado tonneau, Tacoma bed mat, Plasti Dip Badges, Tailgate mod, Fog light anytime mod, Toytec (TTHA-CK) 3" lift kit w/height adjustable coilovers, 5100's w/Eibach coils, TSB AAL, LR UCA's, CB drop kit, Diff drop kit, XD spy's on 285/70/17 Duratrac's
    I'm looking for advice/options to get a factory rake (rear high) look.
    I recently installed Toytec-TTHA-CK 3" lift kit, 5100's all around with 620 Eibach springs up front set at .85, TSB 1 1/2" AAL w/2.5 degree axle shims. As she sits now its pretty much level to the eye. When you measure, its approximately 1/2" higher in the rear. Whats my best option to achieve more "rear high" rake?
    Will the new 5100's I just installed in the rear be long enough if I go any higher in the rear? The new 5100's that came in the kit are listed as "extended length 5100's".....
    1. New leaf pack? (I like the Dakars)
    2 Rear block 1/2"-1" to join the AAL?
    3 Other option?
    This is my daily driver and I do not go off road. Im hoping to not replace the new rear shocks, as these are 3 weeks old. But I will if needed.
    Thanks in advance
  2. Mar 21, 2013 at 12:57 AM
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    I'd put the Dakars on. I've got the Toytec ultimate lift kit with the dakars and don't like it because i can't level my truck up. The Dakars will give you every bit of 3" or more in the rear. I do have the extended travle rear shoks though. Should have just put a Pro Comp 6" lift on and been done with it..lol
  3. Mar 21, 2013 at 7:04 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
  4. Mar 22, 2013 at 4:41 AM
    Sport2012
    NJ
