Factory speakers back in... window's wont work
Discussion in 'Audio & Video' started by Tidrow, Jun 14, 2012.
  1. Jun 14, 2012 at 7:43 PM
    Tidrow
    Tidrow [OP] Well-Known Member
    Austin
    PreRunnin' 08
    BHLM, All Black grill, Fog light Mod, AFE pro dry, 20% tint, Weathertechs, Kenwood deck, Bridgestone AT Revo 2
    So I put the factory speakers back in. I didn't put the tweeters back in. I left the speakerwire for the tweeters unconnected because I don't have the factory tweeters anymore. The door speakers work, but the windows do not. I checked the plugs, they are plugged in. The power locks work. I think I checked the fuse but I'm not sure if it was the right one. Any knowledge would be awesome. I'm working on it tonight.
    I'm thinking I should run the wire from the tweater into the door speaker :confused:
  2. Jun 14, 2012 at 8:22 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    You sure you plugged in the second harness for the window switches on the passenger side? I'm betting you didn't.
  3. Jun 14, 2012 at 8:28 PM
    Tidrow
    Austin
    PreRunnin' 08
    I did boss, as soon as it didn't work I took the panel right back off and checked again... I'm about to take the doors off again. I bet I have to wire in the tweeter wire to something.
  4. Jun 14, 2012 at 8:31 PM
    Tidrow
    Austin
    PreRunnin' 08
    come on Stallion, help me one last time before I trade in my truck LOL
  5. Jun 14, 2012 at 8:34 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Hold the phone, you took off the PASSENGER side window button panel too?
  6. Jun 14, 2012 at 8:35 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I think they are wired in series with each other so if you forgot one of the 2 harnesses that go into the window/lock switch on the passenger side the one on the drivers side wont work either.
  7. Jun 14, 2012 at 8:42 PM
    Tidrow
    Austin
    PreRunnin' 08
    yeah i checked both of them... they are plugged in
  8. Jun 14, 2012 at 8:44 PM
    Tidrow
    Austin
    PreRunnin' 08
    going back out to triple check em, if they are plugged in I'm going to try and run my loose tweeter wire to the woofer
  9. Jun 14, 2012 at 8:59 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I wouldn't do that. The stereo is a totally independent system. It has NOTHING to do with the windows. Hell I haven't had stock speakers or used ANY of the stock wiring for about 3 years.
    Check all the harnesses and make sure they're in all the way. I know there's two on the passenger side and the large one on the drivers side is a little tricky. Make sure it locked in place.
    PS: My memory is fresh because I did an install for someone tonight....like an hour ago.
  10. Jun 14, 2012 at 9:01 PM
    Tidrow
    Austin
    PreRunnin' 08
    they are all three hooked up. Why would the door locks still work?
  11. Jun 14, 2012 at 9:29 PM
    ItalynStylion
    Steven
    DFW, Tx.
    No idea. It's possible you popped a fuse but highly unlikely. Is that stupid window "lockout" button pressed in?
  12. Jun 15, 2012 at 7:37 AM
    Tidrow
    Austin
    PreRunnin' 08
    You got it. It popped a fuse. We are back up and running. Thanks for all your advice bud. You have helped me out several times. PM me when you come to Austin.
    :cheers:
  13. Jun 15, 2012 at 8:05 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Nice. I wonder how that happened. Very odd. But glad you got it worked out!
