Factory Tow hitch Hooks Broken?
Discussion in 'Towing' started by aidenhardcore, Jun 8, 2011.
  1. Jun 8, 2011 at 5:55 AM
    aidenhardcore
    aidenhardcore [OP] Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    Hey guys. I got my 2010 tacoma stuck real bad couple weeks ago in woods. Had to get it pulled out and while doing that broke my 2 tow hooks on the factory tow hitch. I want to get them fixed but dealer said i would have to buy a whole new hitch. Im going to be towing my 19foot boat this weekend and would like to put the chains there in case the ball came out. How would i fix it. Maybe weld them back togther maybe by a shop, idk lol. I was thinking just taking the hooks from tailer and hooking them to the under of the hitch since the tow hook loops are broken . Please give me advice. Thanks guys
  2. Jun 8, 2011 at 6:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You shouldn't tow a stuck vehicle out with those hooks, they're not made for that kind of load, get a receiver mounted shackle for stuff like that. As far as fixing your problem, are the chains long enough to wrap around the hitch frame itself as a temporary fix until you can replace the factory hitch? Otherwise, places like Uhaul could get you set up with a new hitch fairly quickly. I suppose a good welding shop could fix it for you if the only thing that broke was the hooks on the sides but make sure nothing else is bent.
    Oh and...
    :worthless:
    EDIT: OP, next time use one of these and a good tow strap. http://www.tacomaworld.com/forum/elite-off-road/90840-elite-off-road-receiver-hitch-shackle.html
  3. Jun 8, 2011 at 8:07 AM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    Like the other guys said you shouldn't really ever pull from those. Safety chains on there only. However, that's easy to say when you're not stuck in the woods and it's getting dark or something and you don't plan to abandon your truck for a week while the UPS guy brings you the tow loop you walked home to order.
    A strap with a loop on the end can work well with a trailer hitch pin in the receiver too. But you probably didn't have anything in the receiver either.
    If it's just the hooks that got messed up you should be able to have them welded. Depending on the length of the chains just have a look around under there. You can see how beefy looking the factory hook points are (are aren't) so maybe you can find something else sturdy enough to hook them to temporarily.
    I ordered my recovery loop with a big solid shank and large D-ring from e-trailer, was about $35. I keep it under the back seats by the jack all the time because you never know. If you're going to buy a strap, the recovery straps are much stronger than tow straps. Recovery straps have some stretch to them so they don't snap when they get taut.
  4. Jun 8, 2011 at 8:35 AM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    Thanks for the infor guys. I was so stuck and I mean stuck I had to leave my truck overnight in the woods. Omg it was bad. I know I shouldn't have try to pull out from the hooks but after 6 hours of trying to get my brand new truck out from mud, anything would have helped. I don't think the tailer chains ate longer enough to go around the back side of the hitch but I'll check. The hitch itself is fine so no way I'm going to spend another 200 to fix it when just the hooks are broken. Next time I'll get a better d rings and stuff like you guys said. Thanks
  5. Jun 8, 2011 at 8:44 AM
    rackatak
    rackatak Well-Known Member
    Something I did before I got my receiver shackle from elite offroad was taking a recovery strap with loops in the end and feeding it through the receiver and looping it back over itself. I know it doesn't help ya now but maybe in the future if you get in a similar predicament.
  6. Jun 20, 2011 at 1:16 AM
    JKD
    JKD Well-Known Member
    Figure out a way to hook your trailer chains up PROPERLY. You can kill someone if that safety backup isn't there.
  7. Jun 20, 2011 at 3:18 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    aidenhardcore,
    2 things; 1st find a GOOD weld/fab shop to weld those safety LOOPS back on,maybe up grade ....2nd ...buy that dam receiver-D-ring set-up.....Amazon or a good local 4x4 shop will have them...better yet CHECK TW vendors...guess what, one of them sells them...
  8. Jun 20, 2011 at 5:43 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    ^So you provide him with Amazon but dont give him the vendor on TW that sells them? Nice. Maybe you should help out the vendor and the OP and not keep it a secret
  9. Jun 29, 2011 at 4:57 PM
    Shenandoah
    Shenandoah Member
    Virginia
    09 Double Taco SR5 Off Road
    Tonno Tri-Fold, Extend-A-Truck Hitch
    Ok I'm just curious why people are buying these when they could just carry a wrench and take the ball out of there hitch and put the d-ring in?
  10. Jun 29, 2011 at 6:46 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Pfffft that takes effort
  11. Jul 16, 2011 at 6:48 AM
    hunterorange
    hunterorange Active Member
    western mass
    2011 crew cab, short bed, TRD sport
    all pro sliders with rino liner on them, and my yakima canoe rack.
    let me just ask you one thing..... where did you find woods in boston?
