Factory TRD Off Road suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jigstick, Sep 23, 2023.
  1. Sep 23, 2023 at 1:06 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    the official factory lift removes the fog lights I believe per other discussions on the topic
    RIX TUX and gsubioguy like this.
  2. Sep 23, 2023 at 1:08 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  3. Sep 23, 2023 at 1:15 PM
    TyRoosevelt
    TyRoosevelt Well-Known Member
    Colorado Springs, CO
    2023 Tacoma TRD Offroad
    2.5 inch Dobinson Lift Accutune UCAs 285 70 17 Baja Boss Tires Method Wheels Meso Customs full blackout interior RSG Sliders Bakflip Revolver Tonneau
    I would not put pizza cutters on. I personally think they look odd. You can get an all terrain 265 70 17 and it looks nice on stock suspension. If you get at least a 2 inch lift, get accutune uca’s, and set them to 3 degrees of caster. Then you can fit a 285 70 17 without a chop or any fender cutting. That is what I did and I have fully flexed it.
  4. Sep 23, 2023 at 1:26 PM
    AK Dudeman
    AK Dudeman Well-Known Member
    DCBLB OR MGM 22
    The Fog light deal on the Lifts, depends on which State & Dealer. Mine stayed on truck done in Washington & Shipped to Alaska. & been verry Happy so far.
    Barsoom, Coldpunk and BC Hunter like this.
  5. Sep 23, 2023 at 1:48 PM
    Jigstick
    Jigstick [OP] Well-Known Member
    2023 TRD OR LB
    I’d love to lift mine 2-2.5in max. I don’t want to get into cab chips and needle bearings. 33s are plenty tall for me. Just need 1-1.5in of ground clearance and I’d be happy. Lots of ruts on the farm
    slinkz419 and LeakyAC like this.
  6. Sep 23, 2023 at 2:11 PM
    JimBob151
    JimBob151 Member
    2022 MGM OR
    OME 2.5” Medium Rear (600); Decked, Leer
    I was at a dealer I frequent yesterday. A ghod friend who is a salesperson, mentioned to me that he saw a “lift” option in the “extras” category, that was bot the “TRD Lift” option. The vague details of that lift, were 2” front and 1” rear. To which I responded “sounds like a block-lift or leveling kit”. And the price tag on it was just over $3100. Try not to be shocked at the cost compared to what you get at a dealership. Lol.
    gsubioguy and Chew like this.
  7. Sep 23, 2023 at 2:35 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Your truck is how all TRD Off Road trim packages come from the factory. There is a small spacer on the rear but it is NOT the OEM TRD Lift kit. I think there is a sticky thread on what tires fit on specific stock trim packages. I’m pretty sure 32-33in tires are going to require an optional lift.
    BC Hunter and LeakyAC like this.
  8. Sep 23, 2023 at 4:34 PM
    Jigstick
    2023 TRD OR LB
    So 33in pizza cutters probably aren’t going to fit?
  9. Sep 23, 2023 at 4:43 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    BC Hunter likes this.
  10. Sep 23, 2023 at 5:59 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    From my understanding a 255/80r16 will fit on a stock set up with stock wheels. You may tag the mud flap but I stand with the other opinion of a 265/75r16 is better suited. I ran a 265/70r17 for a year on all stock with no issues. Have a buddy with this set up and that truck goes everywhere you could want.
  11. Sep 23, 2023 at 6:14 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Yea yours is stock I have all those same parts sitting in my garage after I lifted my truck.
  12. Sep 24, 2023 at 10:51 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Don’t need lift for 32 or 33. Stock sr5 running 33. Had 32 before.
  13. Sep 24, 2023 at 12:25 PM
    Jigstick
    2023 TRD OR LB
    what wheel and tire are you using
  14. Sep 24, 2023 at 12:36 PM
    PTSDTherapy
    22 SR5 DCSB
    Stock sr5 wheels 16x7 +25 offset. Had 235/85/16 in e rated geolandar’s before and now running 255/85/16 in Yokohama g03. Only rubbed the right front wheel well liner about 1/2 inch by 1 in at full compression at left turn on the G03. That stopped after some wear. Never enough to even think about.
    You don’t need wide tires if you are going off-road. If you’re going off-road and need to look good to impress someone then go wide and do a chop and a bunch of other stuff. I stick to what works and what doesn’t need more money thrown at it to work. And I’m still on stock suspension. My truck just works and works it’s ass off well.
    raleigh5, BC Hunter and Jigstick[OP] like this.
  15. Sep 24, 2023 at 12:39 PM
    #35
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    255/85/16 or 255/80/17 will fit no problem as long as you used a factory wheel or something with similar specs. I think the pro wheels have a different offset so they will not fit
  16. Sep 24, 2023 at 12:45 PM
    #36
    PTSDTherapy
    22 SR5 DCSB
    This is a true statement. I think if they made a 255/90/16 it would fit as well. Stick to stock wheels with + 25 and I think the other trucks have a +30 ( someone will correct me I’m sure if I’m wrong). Aftermarket wheels that may advertise a +15 through +25 may not fit the tires correctly in the wheel well. Ask me how I know.
  17. Sep 24, 2023 at 1:47 PM
    #37
    Jigstick
    2023 TRD OR LB
    I’m just looking to get around the farm better. Clear the ruts, stumps, logs, etc. I think 33in tires will be plenty. If I can avoid a lift I’d prefer that
  18. Sep 24, 2023 at 3:22 PM
    #38
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    no rear blocks
    Chew likes this.
  19. Sep 24, 2023 at 5:22 PM
    #39
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    That's not a block. Spring pearch weld on axle. They all have that.
  20. Sep 24, 2023 at 5:37 PM
    #40
    TyRoosevelt
    If you get the trd lift kit, it rides almost exactly like stock. It will be really difficult for you to fit 33s without a lift and aftermarket control arms. You could probably fit a 275 70 17 with a spacer lift and some minor trimming.
