Factory Tweeters?
Discussion in 'Audio & Video' started by rwcfrank, Mar 26, 2009.
  1. Mar 26, 2009 at 5:59 PM
    rwcfrank
    rwcfrank [OP] Well-Known Member
    08 SR5 Prerunner
    I just upgraded my head unit and front speakers. I have a 2008 double cab with non JBL. I left the factory tweeters in place even though the new speakers have built in tweeters. Should I go back in and remove the factory tweeters or not? Next come the rear door speakers...
  2. Mar 26, 2009 at 6:05 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    um, you might want to remove those factory tweeters. because, if you already have coaxial speakers, it might distort the sound quality to just leave the old factory tweeters in place.
  3. Mar 26, 2009 at 6:11 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Good luck trying to figure out how to get them out! I couldn't
  4. Mar 26, 2009 at 6:19 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    You have to take off the door panel in order to get into the door where the tweeters are. Like beastlytaco said just unplug them and let them stay there.
  5. Mar 26, 2009 at 6:19 PM
    DanGer
    but they are wired in series with the woofers so you unplug them the whole thing loses signal
  6. Mar 26, 2009 at 6:22 PM
    Lentsnh
    Do a direct connect with the woofers
  7. Mar 26, 2009 at 6:26 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    I left my tweeters in after I installed everything, figuring that I'm going to take them out once they I blow them. My aftermarket speakers have the tweeters on them as well. So far, a year and change later and they still haven't blown. So, you can leave them alone if you want. But thats my IMHO.
  8. Mar 26, 2009 at 6:29 PM
    Lentsnh
    No sound issues? distortion
  9. Mar 26, 2009 at 6:54 PM
    DanGer
    mine are still hooked up until i replace my after market speakers with components. No issues with sound what so ever
  10. Mar 27, 2009 at 10:32 AM
    rwcfrank
    08 SR5 Prerunner
    It sounds great considering I havent updated the rear speaker yet, I apreciate the comments and I glad I waited because I was going to snip the tweeter wires and that would have caused quite the headache if they affect the speakers...
  11. Mar 27, 2009 at 10:52 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Or, you can do what I did - just bypass all the factory wiring, run new speaker wire and hook up amps to your new headunit... :D
  12. Mar 27, 2009 at 11:25 AM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    Or you could just disconnect it and be like "I have 4 tweeters...but only 2 work." :p
  13. Mar 28, 2009 at 7:49 PM
    rwcfrank
    08 SR5 Prerunner
    Okay so I am going to stick with the factory tweeters for now. I just got a set of Blaupunkt "system" speakers for free. They have the sperate tweeters, Can I install these in the rear without tweeters? Or should I swap the front speakers to the rear and intall the Blaupunkts in the front with the factory tweeters???
  14. Mar 29, 2009 at 7:51 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I snipped mine. I cut the wires at the white tweeter connectors. There are four wires. Splice like colors together (e.g. blue to blue, green to green).
  15. Mar 29, 2009 at 7:55 PM
    Evil Monkey
    Robert
    Escondido, CA
    They're not series. There are four wires at the connector but only two at the tweeter. There's a tap inside the harness. It goes away because the splice to the tweeters is between the tweeter and the white connector. When you disconnect the white connector, you're cutting the wire source to the woofer as well as the tweeter. I tried splicing the two connectors at the tweeter and the sound in the woofer went away. Since they were in parallel with the woofer, it created a short around the woofer. If they were series, splicing them at the tweeter would have been like a straight wire to the woofer.
    If you splice the like-colored wires at the connector (blue to blue, green to green), it'll work. I think you can also just cut the one of the two wires at the tweeter. I spliced because I didn't want a free wire hanging in there.
  16. Mar 29, 2009 at 8:22 PM
    Evil Monkey
    Robert
    Escondido, CA
    Here's my highly technical drawing :). The arrow is pointing at the connector you disconnected. You can see why it would lose signal even though they're parallel.
  17. Apr 6, 2009 at 7:42 AM
    rwcfrank
    08 SR5 Prerunner
    After breaking in the speakers I noticed its a little tinny with the factroty tweeters running. I am not %100 sure on your explanation evil monkey can you clarify please?
  18. Apr 6, 2009 at 9:16 AM
    Evil Monkey
    Robert
    Escondido, CA
    My explanation pertains to the white connector that runs to the tweeter (should be high on the door near the tweeter). There are four wires running through that connector, two pairs of the same color. Wires then go through a black plastic conduit with only two wires coming out the other side, which connect to the tweeter. I don't remember the colors on the left side (I think it was red/black). On the right side of my truck, those pairs are green & blue (two green wires & two blue wires). I clipped the connector out (either side of the plug, it doesn't matter) and spliced together the like-colored wires: splice blue to blue and splice green to green.
    Alternately, you can just cut one of the two wires at the tweeter itself. Either one. It doesn't matter.
  19. Apr 6, 2009 at 10:16 AM
    rwcfrank
    08 SR5 Prerunner
    Now I get it!! Thanks very much!!!!
