Fail Safe on Starting After Accident
Discussion in '1st Gen. Tacomas (1995-2004)' started by 90YotaPU, Feb 15, 2012.
  1. Feb 15, 2012 at 3:13 PM
    90YotaPU
    90YotaPU [OP] The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    The son of a coworker of mine spun out the other night and hit a guard rail at highway speed. Now the truck won't start. Is there a fail safe on the Tacos that maybe cuts off the fuel pump or relay after an accident. Truck is an '04 4x4 V6. Thanks.
  2. Feb 15, 2012 at 5:44 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    theres none to my knowledge. Will it just not turn over?
  3. Feb 15, 2012 at 5:52 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Is it possible there's a broken post on the battery from the jolt?
  4. Feb 15, 2012 at 5:58 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    That is what I was thinking as well. Could have jarred the battery around a bit and broke/loosened a connection somewhere in there.
  5. Feb 15, 2012 at 11:47 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    does it turn over or not?
  6. Feb 11, 2022 at 12:05 PM
    Joetx
    Joetx Member
    2003 Tacoma Prerunner
    Sorry to bump this old thread, but same thing happened to us. Any update?
  7. Feb 11, 2022 at 12:22 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    At least on automatic trucks, there is a little plastic cover you can remove and reset the tab inside it:
    I looked through the owners manual but didn't see it specifically mentioned.
    Toyota calls the little cover Automatic Transmission Shift Cover Plate Cap
    Joetx likes this.
  8. Feb 11, 2022 at 12:36 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    That's an override if you can't shift into drive. At least that's what page 205 of the 2019 Tacoma manual says. It gives the procedure of what to do if you can't get the transmission to shift out of Park.
  9. Feb 11, 2022 at 12:50 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Fun fact
    Tap the members name you'll see he was last on TW in 2018
    Welcome to TacomaWorld
    Bivouac likes this.
