Failed My Emission test
Discussion in '1st Gen. Tacomas (1995-2004)' started by gmata, Nov 30, 2009.
  1. Dec 4, 2009 at 4:24 PM
    #41
    gmata
    gmata [OP] Well-Known Member
    Gonzalo
    Delaware
    2007 DCB 4x4 TRD sport
    I am actually scared is going to be something bad inside the engine :( i feel a slight vibration at about 2800 RPM on every gear even on neutral with the truck completly stopped. :mad:
  2. Dec 5, 2009 at 10:17 AM
    #42
    gmata
    Gonzalo
    Delaware
    What do you guys think about that vibration? has any body else experienced something like that?
  3. Dec 5, 2009 at 10:23 AM
    #43
    98tacoma27
    Ben
    Not Beech Creek
    Don't worry about it until you get the misfire corrected. They could be related.
  4. Dec 5, 2009 at 10:49 AM
    #44
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    vibration is probably caused by skipping cylinder.
    Just an idea, alot of aftermarket wires like accel have less impedence than stock making them peform better. Well they perform better on older vehicles that arent controlled by computers, like my 79 chevy BB. I have a 2000 s10 that had a misfiring cylinder and replaced plugs and wires with performance ones. They through the check engine light saying multiple misfires. I went to chevy to talk to my buddy who works in service and he let me barrow a set to see if theyd clear the codes and they did so i used his discount, bought them and havent had any issues since. He said that, in stock system, if the wires impedence isnt matched with coil output it can cause trouble codes and even misfires.
  5. Dec 5, 2009 at 11:00 AM
    #45
    gmata
    Gonzalo
    Delaware
    So when you say skipping Cylinder? do you mean caused by the missfire?
    I understand the importance of using stock parts for spark plugs, and wires. I have replaced my Sparkplugs with densos, and my NGK wires should be here on tuesday.
  6. Dec 5, 2009 at 11:09 AM
    #46
    98tacoma27
    Ben
    Not Beech Creek
    skipped cylinder = misfire
  7. Dec 5, 2009 at 11:19 AM
    #47
    Yoytoda
    Roland
    completely stock
    yes skipping= misfire
    when running the firing order skips that cylinder indicating a misfire
  8. Dec 5, 2009 at 11:27 AM
    #48
    gmata
    Gonzalo
    Delaware
    Please excuse my ignorance but, do you guys mean that the cylinder is skipping because i have a missfire and the problem could be the wires or coil or something like that?
    Or you guys suggesting that i have a missfire because the cylinder is skipping and the problem could be something different?
    I know it sounds dumb but just wanted to clarify.
    Thanks
  9. Dec 5, 2009 at 11:31 AM
    #49
    98tacoma27
    Ben
    Not Beech Creek
    Skipping (misfire) means that the cylinder didn't fire when it was supposed to. You are reading a little too deep into it. You are on the right track so far with the coil and wires. Misfire and skipping are interchangeable words in this case.
  10. Dec 5, 2009 at 11:34 AM
    #50
    Yoytoda
    Roland
    completely stock
    x2
  11. Dec 5, 2009 at 11:42 AM
    #51
    gmata
    Gonzalo
    Delaware
    ok Thanks just wanted to clarify that, now i read on another forum and it got me thinking... each coil controls 2 cylinders right? so if it was coil that was faulty shouldn't i be having Engine missfire in 2 different cylinders? I am just thinking a little bit ahead just in case the wires don't fix the problem when i get them next tuesday.
  12. Dec 11, 2009 at 3:14 PM
    #52
    gmata
    Gonzalo
    Delaware
    Its been a few days since i posted last.
    This is where i am right now.
    Finally i was able to pass the emission test after i changed the spark plugs reseted the codes and drove for about 20 miles, i went to emission test and passed. :D
    Driving back from emission test the CEL comes on again!!! :eek:, sames codes P0300 and P0301.
    I got the Spark plug wires next day, NGK i installed the new wires and reseted the codes again. 50 miles went by and suddenly CEL again!! :mad:.
    I went to the Auto hobby shop at the Airforce Base, and i checked for compression on the cylinders, fearing it would be a valve. Fortunetly all looks normal.
    Then i Changed the Coil pack from Cyl 1 to Cyl 2 maybe i would get a code for Cyl 2 this time and the coil pack was the problem. 15 miles later CEL light comes again as expected and Missfire on CYl #1 again.
    So....
    It is not the Spark plugs, Wires, Valves, Coil.
    What else could be causing this problem??? i am out of ideas.
    Please help.
  13. Dec 11, 2009 at 3:30 PM
    #53
    98tacoma27
    Ben
    Not Beech Creek
    It could be that injector.
