Fall Camp & Ride (Oct. 20-22, 2017)
Discussion in 'Florida' started by Taco No Baka, Jul 8, 2016.
  1. Oct 24, 2017 at 2:59 PM
    #1681
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Still can’t believe my dumbass forgot I unlocked my hubs lol. But oh well, didn’t need it
  2. Oct 24, 2017 at 3:00 PM
    #1682
    allenfab
    Todd
    Lakeland, FL
    And this setup didn’t get stuck on graveyard, but mine did lol. Still can’t get over that
  3. Oct 24, 2017 at 3:37 PM
    #1683
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    And you told me to give up. :cool: I smoked my tires a few times this weekend trying to do some things
    allenfab[QUOTED] likes this.
  4. Oct 24, 2017 at 3:50 PM
    #1684
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    A 1st Gen Xtra Cab wheelbase is only 5" shorter than a DCSB/Access Cab and 18.5" longer than a single cab 1st Gen, although Todd has lengthened his wheelbase some moving the axle forward during the SAS and I've moved my rear axle back an inch. Not sure how much difference there is between us now. So I'm 4" shorter in wheelbase than a 2nd Gen DCSB. Not sure how much difference that would make, especially compared to 2nd Gen on 35s with me on 33s.
    As for the other stuff, I think the front bumper moved up in priority after I dicked the plastic one up last weekend. I'm considering my options since I can't afford a winch and I'm certainly not buying one before I regear. I'm thinking about just going with a tube bumper type thing that will give me a better approach angle and better recovery points but with no winch option.
    As for bobbing the bed, I don't see that happening. I do need to use the truck as a truck from time to time. The most I'd do is cut the lower rear bed sides and put a closely tucked high clearance bumper with recovery points and an integral receiver hitch on it so I can ditch the rock anchor hitch and stock bumper to get a little better departure angle.
    Heh, I thought you at least has an LSD unit. Did they get rid of the LSDs and just go pure ATRAC with your year TRD Sport?
    Haha, shit happens, but nope, didn't need it at all. :thumbsup:
  5. Oct 24, 2017 at 4:14 PM
    #1685
    Timbo's Customs
    Timothy
    Lakeland FL
    The 2012 and up have traction control via the abs I believe. My traction control system is disabled due to the steering angle sensor being messed up from a rough alignment when I did my cam tabs. Tried to reset it but oh well. My next big purchase for the truck is 4.56s and a locker until then I’ll be one wheel peel
  6. Oct 24, 2017 at 5:00 PM
    #1686
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I can switch from Traction control to auto lsd to open diffs by pressing one button. Then there is 4 hi 4 lo. 4 lo with rear locker or 4 lo with rear locker and A-trac. 90% of the time at Citrus im locked in 4lo J/K. I run LSD
  7. Oct 24, 2017 at 5:04 PM
    #1687
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Correct. The sport since 2012 or so has a simulated LSD using brake modulation. It works to some degree, but not as good as a locker by any means. I think it's good for not really deep sand, snow and sloppy fire roads mostly, but not for deep mud or rock crawling. It works on both the rear and front axle in 4Hi, but 4Lo it's disabled (but easily tricked into working in 4Lo with a quick snip snip of a wire or two).
    I had a blast, I think my favorite part was the BS sessions around the fire. Some of you guys are crazy (in a good way)!
    Already looking forward to February.
  8. Oct 24, 2017 at 5:05 PM
    #1688
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Ive had my truck forever,so its paid for. No fancy traction devices, except an LSD thats worn out and doesn’t do shit really. I just dont want to damage my truck,i dont really have anything to prove. Im still learning what it’s capable of. Although the more shit i keep putting on it, i wont have anymore excuses not to see what it can do. lol.
    Edit, i also need to sack up and camp. That seems like the best part of the whole thing, ive been missing out.
  9. Oct 24, 2017 at 5:20 PM
    #1689
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    If I remember right we (sports) have LSD but it's electronic not mechanical. I believe the switch to electronic was in 09. I think it basically cuts power when the wheel starts to slip. At least this is my understanding.
    I turn my traction control off to stop it from cutting power in the sand.
    That's what I do, just by hitting that button make a big difference.
    NABeast and TacoTRD78[QUOTED] like this.
  10. Oct 24, 2017 at 5:21 PM
    #1690
    TacoTRD78
    Stuart,fl
    Its impressive what the LSD will get you through.
    NABeast and SpruceTaco[QUOTED] like this.
  11. Oct 24, 2017 at 5:29 PM
    #1691
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I know I didn't get too crazy but I didn't have any problems with what obstacles I did do. Needed a little more skinny pedal in the sand a couple times. Haha
    TacoTRD78[QUOTED] likes this.
  12. Oct 24, 2017 at 5:31 PM
    #1692
    JaxJim
    Jim
    Jacksonville, FL
    This thread explains how it all works. https://www.tacomaworld.com/threads...ntrols-trac-auto-lsd-trac-off-vsc-off.464400/
    SpruceTaco[QUOTED] and TacoTRD78 like this.
  13. Oct 24, 2017 at 5:40 PM
    #1693
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
  14. Oct 24, 2017 at 6:04 PM
    #1694
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    If you hold the button down for a few seconds while completely stopped, it will turn it off and yiu should get a light that says TRAC OFF
    SpruceTaco[QUOTED] likes this.
  15. Oct 24, 2017 at 6:15 PM
    #1695
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    This I did not know. Learn something new every day!
    It seems to work pretty good the way I've been doing it.
  16. Oct 24, 2017 at 7:26 PM
    #1696
    Trident904
    Brian
    17 4Runner TRD OR
    Even better when you hold it down long enough!
  17. Oct 24, 2017 at 8:34 PM
    #1697
    JaxJim
    Jim
    Jacksonville, FL
    This mode works a lot like limited slip on both axles, There is no throttle retardation, just brake application to the wheel that slips all handled through the ABS system. It does work pretty well. It does get disabled in 4Lo unless you do the "Yellow Wire Mod" which is super easy to do, the wire lives behind the glove box and takes about 10 minutes tops to perform the mod. Look it up on here: https://www.tacomaworld.com/threads/4low-trac.51946/
  18. Oct 24, 2017 at 9:25 PM
    #1698
    Taco No Baka
    Lee
    Tampa, FL
    So how many of the TRD OR 4WDs have performed the gray wire mod (Rear Locker Anytime)?
  19. Oct 24, 2017 at 9:54 PM
    #1699
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    I did it
  20. Oct 25, 2017 at 4:01 AM
    #1700
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Too many essays up in here
    5 Lug Fury and Timbo's Customs like this.
