Fan blowing only when on high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, May 22, 2016.
  1. May 22, 2016 at 12:31 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    My cab fan (heat/AC, not engine cooling) blows only when the knob is set on high. Anything else, nothing.
    Is this a common issue? What could the problem be?
  2. May 22, 2016 at 12:34 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Search "blower motor resistor" in the search bar.
    It's a common problem on the older second gens. Easy fix though, replace the electrical resistor pack and connector. Done right, it's about $30.
  3. May 22, 2016 at 12:35 PM
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    Resistor block probably failed
    foampile[QUOTED][OP] likes this.
  4. May 22, 2016 at 12:35 PM
    Tom0662
    Tom
    Iowa
    2016 TRDORSB
    Ahahaha, beat me to the punch
  5. May 22, 2016 at 12:38 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    What they said above. At least as far as auto repairs go its pretty cheap & simple.
    foampile[OP] likes this.
  6. May 22, 2016 at 12:51 PM
    foampile
    Mid-Atlantic
    Thanks, everyone
  7. May 22, 2016 at 1:09 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My fan recently worked only on high, there was corrosion on the resistor pack terminals. Unplug, a squirt of contact cleaner and plug back in and it works but I can see the need for replacement resistor pack in the future. At least it's not buried deep in the hvac system to keep it cool like in some vehicles.
  8. May 22, 2016 at 4:22 PM
    HoosierTaco06
    HoosierTaco06 Well-Known Member
    Jeff
    Northwest Indiana
    2006 Tacoma TRD Off-Road
    Locker anytime, ABS killswitch
    Lester Lugnut and foampile[OP] like this.
  9. May 22, 2016 at 5:26 PM
    el_turks
    el_turks Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
  10. May 30, 2016 at 11:53 AM
    18576 Member
    I have replaced this part once on my 2008 (150,000 miles). About two months ago the problem statred again. I ordered the part and naver got around to installing it until today. I unplugged it and plugged it back in and all fan speeds are working. I will keep the part for back up of course.
  11. May 30, 2016 at 6:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is coming and going like that it isn't a bad resistor it is a loose connector. I'll bet it is burned and getting worse the longer you wait.
  12. May 30, 2016 at 7:26 PM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    This is correct. The resistor pack itself is not the cause of the problem. The problem occurs due to the female terminals on the resistor being too loose, burning the connectors and corresponding wires. Thus the TSB resistor pack with stronger terminals.
  13. Jan 10, 2023 at 6:28 PM
    foampile
    Mid-Atlantic
    is it the same as blower motor relay?
  14. Jan 10, 2023 at 6:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  15. Jan 10, 2023 at 7:05 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma DblCab SB
    buy the new style one, its square, 4 pin, not flat!! Save you from doing it again...
  16. Jan 10, 2023 at 7:17 PM
    foampile
    Mid-Atlantic
    will it fit in the old slot?
  17. Jan 11, 2023 at 5:09 AM
    MSgt O
  18. Jan 11, 2023 at 5:11 AM
    MSgt O
    Old Harness -> -> New Harness
    White/Blue Stripe -> (Hi) -> Solid White
    White/Black Stripe -> (Lo) -> White/ Black Stripe
    Green/Yellow Stripe -> (M1) -> Solid Green
    Blue/Black Stripe -> (M2) -> Solid Blue
