Fan bracket bearing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Apr 16, 2025.
  1. Apr 16, 2025 at 10:06 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
  2. Apr 16, 2025 at 10:13 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Sounds crunchy sometimes
  3. Apr 16, 2025 at 10:18 AM
    Kristi with a K
    Western MA
    Does that mean you second the bearing/bracket? I do agree there is an off noise…. I’m also seeing that inner pulley wobbling.
  4. Apr 16, 2025 at 10:25 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    That new csp sure looks sweet spinning down there, kristi
    I will listen for any odd noises
    Sometimes it seems hard to tell with the 5VZFE if it's normal or abnormal
    But definitely do NOT want this bearing in the bracket to seize and break!
    Kristi with a K[OP] likes this.
  5. Apr 16, 2025 at 11:20 AM
    Kristi with a K
    Western MA
    Ok. So I just attempted to spin the fan & whilst I can turn it, that’s it. No 1”, 2”, etc, post rotation, so if I’m correct that there should be some kind of post turn spin/movement, I’m thinkin I need to replace the fan clutch. Also I imagine this would take a toll on the pulley bracket.
  6. Apr 16, 2025 at 1:06 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  7. Apr 16, 2025 at 1:14 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Kristi, are you going to check the oil in the fan clutch first, maybe it just needs some new oil in there?
  8. Apr 16, 2025 at 1:58 PM
    Kristi with a K
    Western MA
    Ha-ha! Great! New one on me! Guess I’ll look that one up. It’s got 265,000 on it. I can force push it with one finger, but it’s got a good amount of resistance. Absolutely no free wheelin. I stop pushin’, it’s more than happy to stop. Other thing is my ac was not blowing out cold air anymore. I guess I’ve not made the connection between the ac & this fan clutch (as opposed to the ac clutch). Maybe they work together & I’ve got a whole nother thing to learn & maybe I can have ac back! Anyways, thank you. I can check the oil once I figure out where it goes.
  9. Apr 16, 2025 at 2:00 PM
    Black97v6MT
    iMA0
    tacoLand USA
    https://youtu.be/zjhKr5usjaA?si=vzXQ39MJrRVmGJ60
  10. Apr 16, 2025 at 2:03 PM
    Kristi with a K
    Western MA
    Where does it go?
  11. Apr 16, 2025 at 2:08 PM
    Black97v6MT
    iMA0
    tacoLand USA
    The new or the old?
  12. Apr 16, 2025 at 2:54 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  13. Apr 16, 2025 at 3:19 PM
    Kristi with a K
    Western MA
    the oil. I looked it up & all I saw was how to replace the fan clutch.
    Just for reference, this is what mine looks like
    Black97v6MT[QUOTED] likes this.
  14. Apr 16, 2025 at 3:27 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Probably best just to put a new part on
    ...just curious what the oil is like or if any had weeped out
    That utube video piped in post #9 shows how to split that part open to clean and add new oil
  15. Apr 16, 2025 at 3:41 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    From your FC pix definitely some seepage going on
    I saw some video where dude RR’d his oil
    IIRC, that little eye dropper bottle of oil was crazy expensive….like had/made from rhino sperm expensive
    agree with black97
    Would just RR
    Black97v6MT likes this.
  16. Apr 16, 2025 at 4:06 PM
    Kristi with a K
    Western MA
    Maybe for fun I’ll do that later. Thanks for posting it. Do you know how often it’s supposed to be done?
  17. Apr 16, 2025 at 4:13 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Not one idea of any interval! Maybe if you notice it weeping and not working properly :notsure:
    Toyota may even sell the special OEM oil for it still?
  18. Apr 16, 2025 at 4:18 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    no idea what a fan bracket is...
    Doesnt the fan clutch, pulley, mount to the actual water pump, just like every other vehicle engine?
    Did you have the timing cover off?
    Could that scraping sound be from cover not properly positioned, maybe overtightened & scraping?
    dont waste your time trying to replace fanclutch fluid....
    if theyre leaking, replace...
  19. Apr 16, 2025 at 4:32 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I was hoping you would delve into this issue, I don’t completely understand how it works, I know you’ll post what you learn.
    :thumbsup:
  20. Apr 16, 2025 at 4:37 PM
    Black97v6MT
    iMA0
    tacoLand USA
    The 5VZFE is a strange special engine
