Fan clutch bad, any tips?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JustADriver, Apr 10, 2023.
  1. May 5, 2023 at 4:15 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Try a dealer site like parts.camelbacktoyota.com to find parts even if you buy elsewhere (McGeorge is an identical search interface, there are lots of them.) They have exploded views and highlighted parts so it's way easier to find part numbers, then you can confirm on the Toyota parts site. I agree, it may be the "final authority" for parts numbers but it's pretty counterintuitive to use.
    You may say you're done tonight, but what if the bolts are very close to coming off? I'm sure most of us (me included, many times) have been right there with you and almost gave up. My go-to is shoot the bolts (AGAIN) with PB blaster, go take a rest (in my case nap LOL) and try again. This actually works. Sometimes. :p
  2. May 5, 2023 at 6:01 PM
    JustADriver
    JustADriver [OP] Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    I got the nuts loose with vise grips and a hammer. I was thinking they were bolts but I didn't have the angle on them to see.
    The Aisin fan clutch indeed has much quieter and normal behavior. I don't understand why.
    Steves104x4 and rocknbil like this.
  3. May 5, 2023 at 8:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Aisin is quality, no reason to get anything else.
    JoeT4R and Steves104x4 like this.
  4. May 6, 2023 at 1:11 PM
    bellybones
    bellybones Member
    1997 2.4 tacoma
    There a a few really great videos on youtube about how to remove fan clutch, open up the clutch and replace the
    very thick oil in the clutch. I have not done this, but I have seen it done and it is a less expensive alternative to
    a POSSIBLE fix to your fan clutch problem. I suggest viewing a few of these- easy and cheap.
    Black97v6MT and Steves104x4 like this.
  5. Dec 5, 2023 at 9:07 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    You happen to remember the part # for the fan bracket bearing you speak of?
    Edit**
    Found Aisin FBT-004 for Correct part.
    slander[QUOTED] likes this.
  6. Dec 6, 2023 at 7:56 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Black97v6MT likes this.
