Fan Clutch from 2003 4x4 TRD - $30
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by MoonCrawler, Aug 3, 2014.
  1. Aug 3, 2014 at 11:01 PM
    MoonCrawler
    MoonCrawler [OP] Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
    Fully functional fan clutch taken out of a 2003 4x4 TRD 3.4L at around 75k. It may be younger than that, but that's when I got the truck. My truck was running 10 degrees hot. I replaced the fan clutch and no change. Turns out the thermostat was in upside down. This fan clutch still works great and has good resistance. These are $150 new from the dealership. Part Number:
    16210-62030
    $30 plus shipping. It's heavy.
  2. Aug 10, 2014 at 11:57 PM
    MoonCrawler
    Sacramento, CA
  3. Sep 2, 2014 at 10:38 PM
    MoonCrawler
    Sacramento, CA
  4. Sep 4, 2014 at 6:36 PM
    trx125
    trx125 Well-Known Member
    PM sent.
  5. Sep 7, 2014 at 12:00 PM
    crazyczech2003
    crazyczech2003 Active Member
    sean
    Gilbert, AZ
    2003 Double 4x4
    Stock, but not for long
    back up PM sent
  6. Sep 10, 2014 at 2:20 AM
    MoonCrawler
    Sacramento, CA
    still available
  7. Sep 10, 2014 at 9:59 AM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Stupid question, which is the heavy unit, the green or orange version, orange right? Mine is green, 2004 PRDC 3.4, non TRD version.
  8. Sep 10, 2014 at 9:23 PM
    SMC1010720
    SMC1010720 Member
    Arthur
    Sacramento, California
    SingleCabs:94 4WD 22RE 5P,95 Tacoma 4WD 3RZAt
    Stock
    Anyone or OP will this work on early 3RZ engines look similar?
  9. Sep 11, 2014 at 1:33 PM
    MoonCrawler
    Sacramento, CA
    I believe the green is the regular and the orange is the heavy unit. I think there may also be another even beefier one if you got the TRD with tow package, but mine does not have the tow package.
  10. Sep 11, 2014 at 1:35 PM
    MoonCrawler
    Sacramento, CA
    Not sure. When I ran the part number, and checked fitting it only showed the 5vz, but maybe it will work?
    I'm in Sacramento too, so no shipping if you find out it will work.
  11. Oct 22, 2014 at 10:49 PM
    MoonCrawler
    Sacramento, CA
