Fan only works in "HIGH"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05RedTaco, Jul 2, 2012.
  1. Jul 2, 2012 at 9:03 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    As title said my in cabin fan only works in "HIGH". What is wrong and what part do I need to replace?
  2. Jul 2, 2012 at 9:10 AM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    Blower motor resistor
  3. Jul 2, 2012 at 9:21 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Yup, my bro had this issue with his Ford Focus and it was the Blower Motor Resistor. For Tacoma's it's part# W0133-1926734. Write up on how to replace, wicked easy.
  4. Jul 2, 2012 at 9:24 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Close, may not be the resistor. I could also being the wiring is overheated. With the fan set on 1-3 wiggle the wires to the resistor plug. I Pull the plug from the resistor and check to see if it's burnt.
  5. Jul 2, 2012 at 9:46 AM
    05RedTaco
    Tony
    Scottsdale
    Good input thanks for responses!
  6. Jul 2, 2012 at 9:50 AM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    Mine was doing that to, the resistor is under the glove compartment, the guide on the 3rd post shows the resistor/connection. I just wiggled mine and it works fine. I think a passenger must have stuck there foot up there and kicked it loose. Try wiggling it around first with the fan set to low see if it will kick on.
  7. Jul 2, 2012 at 9:58 AM
    oldstick
    oldstick Medicare Member
    GA
    Ditto. I got away with just reseating the connector plug on mine. Don't know how long that will last, but so far so good. I did work some ox-guard electrical grease down into the pin sockets before reconnecting.
  8. Jul 2, 2012 at 7:45 PM
    05RedTaco
    Tony
    Scottsdale
    I unplugged the resistor plug then connected it back, works great now :D
