Fastenal Fender Flare Clip Part Numbers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dave333, Oct 3, 2010.
  1. Oct 3, 2010 at 5:48 PM
    Dave333
    Dave333 [OP] Well-Known Member
    Dave
    Loganville
    06 PreRunner TRD long bed dbl cab
    Borla Exhaust, D/T LT, TRD CAI, Hella Rallye 4000, ARB, M/T Sidebiters 16", 265/75/16, Stubbs HD SKO Sliders, OME 3" lift with 886, Dakar Rear leafs, Satoshi
    After having removed my fender flares to be Line X'd I was in need of new clips. I know JB weld holds, but these are cheap from Fastenal.
    Part numbers:
    Blue Nylon Toyota 90904-67036 Fender Molding Clip SKU: 0162693
    Red Nylon Toyota 90904-67037 Fender Molding Clip SKU: 0162694
    They sell them for $11.10 for a bag of 10, I know the dealer is higher. Just thought I'd throw those out there for guys who need the clips.
  2. Oct 3, 2010 at 8:44 PM
    Herculean
    Herculean Active Member
    Brandon
    SoCal
    A/R Chambers, BFG KM2's, Donahoes, Fox 2.0, Sliders, flowmaster, some little stuff.
    Thanks! Do you know how many of each are req'd per flare?
  3. Oct 4, 2010 at 3:51 AM
    Dave333
    Dave
    Loganville
    Yep. They go in a certain order: R = Red, B = Blue.
    Front: R B B B R B B B R
    Rear: B R B B B B R B B B B R B
    Total needed: Red 12
    Blue 32
    Hope that helps.
    SUMMIT556 and jackkpecoraa18 like this.
  4. Jan 4, 2011 at 2:24 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    These are cheap as hell, some don't even fit. Maybe the mounts on the flare are broke. Think I'm gonna use jb weld and seal the deal!
  5. Jan 2, 2012 at 3:24 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Thanks for finding these.
    The dealer wanted $3 each! :eek:
  6. Sep 3, 2012 at 4:39 AM
    Tusk
    Tusk Active Member
  7. Sep 26, 2012 at 9:34 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Did you jb weld the flares? I bought the clips listed above and they are crap. They don't seat into the flare and won't hold. Did you jb the clips into the flare or just weld it to the fender?
  8. Sep 18, 2013 at 3:25 PM
    ARTaco06
    ARTaco06 Well-Known Member
    Arkansas
    2006 4WD DCSB 3" lift HIDs
    Black Powdercoated steps, bullbar, and bumper, BHLM, HID highs/lows, fogs, off roads, 3" lift plasti dipped badges
    anyone else tried these clips?
  9. May 30, 2020 at 8:59 AM
    Squall1120
    Squall1120 Member
    2008 Tacoma TRD
    Is there a way to get the mounts for the back of the flares as well as the clips?
  10. May 30, 2020 at 1:31 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  11. May 30, 2020 at 2:46 PM
    Squall1120
    Squall1120 Member
    2008 Tacoma TRD
    Thank you so much for the help, I also need 6 of the mounting "brackets" that the clips attach to which had snapped off of the flare, do you know if those exist?
