Faulty TRS Projector??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheSmash133, Sep 24, 2012.
  1. Sep 24, 2012 at 8:25 PM
    TheSmash133
    TheSmash133 [OP] Cruise
    Orange County
    2006 Toyota Tacoma Access Cab SR5
    X-D Series Black Rims 12 in sub Amp Super 44 Flowmaster Dual exhaust K&N airfilter Tint Tanneua Snug top Side Steps Blacked out Emblems and lower valence Bright white interior lights Blue dome light Retrofitted Mini H1's and morimoto X-B Halo.....
    Circular dark spot, lower left corner... ^^
    I tried adjusting the bulb, and the knobs on the housing
  2. Sep 24, 2012 at 8:37 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    How did you "adjust" the bulb?
    It goes in one way.
  3. Sep 24, 2012 at 8:39 PM
    TheSmash133
    Orange County
    I realize it goes in one way, I thought it could be off center a little or just wasn't put in correctly. All I did was take it out and make sure it went back in perfectly
  4. Sep 24, 2012 at 8:47 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    What does it look like parked 20ft away from a wall?
  5. Sep 24, 2012 at 8:51 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Do you even have them properly lined?
  6. Sep 24, 2012 at 8:54 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    x2 on the wall pic. Should be a level cutoff and even on bottom. looks to me like you're aimed too low and the dark spot could be part of the truck cutting off some light but it's too weird of an angle/pic to tell. "You have no frame of reference Donny!"
  7. Sep 24, 2012 at 8:55 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's what I'm getting at.
    He posted yesterday that they were pointing up too high and didn't know how to adjust them.
    We can maybe help with a straight-on shot against a wall. Not a lot of help shooting out the driveway and across the street.
    Something more like this...
  8. Sep 24, 2012 at 9:11 PM
    TheSmash133
    Orange County
    This is from sitting in the truck. I really don't have a flat wall/area to adjust..
    Again, left lower hand corner
  9. Sep 24, 2012 at 9:18 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Agree with most above, but, what are they, projector wise?
  10. Sep 24, 2012 at 9:19 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Those are Morimoto Mini-H1 projector retrofits.
    He did it right... he just needs to complete it.
  11. Sep 24, 2012 at 9:21 PM
    TheSmash133
    Orange County
    I'll call TRS tomorrow see what they say, and later on go to my neighbors and use their garage door. They are mini H1's
  12. Sep 24, 2012 at 9:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    They do look low... not throwing any light on that parked car.
    The low side of the cutoff should be 2" below the centerline of the headlight lens.
    You can't properly aim them without a level surface and a flat wall.
    Pull up behind a parked car and ballpark the cutoff just below the top edge of the trunk lid, then drive to Home Depot or Lowe's and aim at their back wall.
  13. Sep 24, 2012 at 9:22 PM
    TheSmash133
    Orange County
    Wow.... finally a decent compliment ;) :rolleyes:
  14. Sep 24, 2012 at 9:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Don't bother TRS until you get them properly aimed.
    If there's still an issue after both are at the proper height, then call Andrew.
  15. Sep 24, 2012 at 9:24 PM
    TheSmash133
    Orange County
    Good idea about Home Depot, and you guys see it too correct? They just look off...
  16. Sep 24, 2012 at 9:29 PM
    t4daddy
    North Alabama
    The very same way I aimed mine. Had people looking at me funny as I was putting masking tape on the walls... There is a link on TRS site.
  17. Sep 24, 2012 at 10:44 PM
    MySilverTaco13
    MySilverTaco13 Well-Known Member
    HBSoCal
    2012 Trd sport PreRunner
    just checked his lights out and tried to fix it but something inside the projectors are obstructing the lower part of the driver side projector i re aligned everything and even fixed the cutoff higher but no fix for the circle shadow i really think its the projector that has the problem
  18. Sep 24, 2012 at 10:48 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    something obstructing the lens maybe shroud out too far??iono
    but rich that pic looks familiar ;)
  19. Sep 24, 2012 at 11:21 PM
    TheSmash133
    Orange County
    I'm gonna contact trs tomorrow about ordering new projectors
  20. Sep 24, 2012 at 11:34 PM
    MySilverTaco13
    HBSoCal
    he has the gatling 2.0 and the projectors fit super flush not like the gatling guns where it is a little recessed
