Faulty TRS Projector??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheSmash133, Sep 24, 2012.
  1. Sep 25, 2012 at 5:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Unless I'm missing something, it's called a fore-ground limiter. It was added to the most recent version of the mini H1 projectors. It can be removed from the projector if you wish. I'll see if I can find the link that explained it from HID Planet.
    From TRS's website:Foreground cutoff The definition of the beam pattern projected on the ground directly in front of a car. Determined by a the foreground cutoff shield if applicable. The shape can usually be modified to your liking.
  2. Sep 25, 2012 at 6:32 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    My next thing.. pugga beat me to it! Go pugga !
  3. Sep 25, 2012 at 6:33 AM
    Pugga
    Massachusetts
    I just learned that yesterday when researching my own projector fit up :eek:
  4. Sep 25, 2012 at 10:46 AM
    TheSmash133
    TheSmash133 [OP] Cruise
    Orange County
    2006 Toyota Tacoma Access Cab SR5
    X-D Series Black Rims 12 in sub Amp Super 44 Flowmaster Dual exhaust K&N airfilter Tint Tanneua Snug top Side Steps Blacked out Emblems and lower valence Bright white interior lights Blue dome light Retrofitted Mini H1's and morimoto X-B Halo.....
    Oh ok! Sweet dude thanks a lot! You saved me a lot of time
  5. Sep 25, 2012 at 12:59 PM
    TheSmash133
    Orange County
    You were right!
  6. Sep 25, 2012 at 7:00 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Best example I could find on short notice :D
  7. Sep 25, 2012 at 7:14 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Pugga saves the day! lol
    Curious as to why they added that..
  8. Sep 25, 2012 at 7:23 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I think it's because they don't want pedestrians or small animals walking in front of the truck to be blinded.
  9. Sep 25, 2012 at 8:07 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Please tell me thats not the reasoning. Lol
  10. Sep 26, 2012 at 5:36 AM
    Pugga
    Massachusetts
    I have my moments... :eek:
    Fortunately, that's not the reasoning. The reasoning is the way your eyes focus or adjust to light. If are on a dark road and there's a big bright spot right in front of your vehicle, you tend to focus on that rather than up ahead where you should be looking. What they did is put a foreground cutoff so that area is dark meaning you can focus on the lit up area further up the road and see what you're actually driving towards. This is the same reason you shouldn't drive with your fog lights on at night (unless in foul weather when they're needed) and also why it's easier on your eyes to dim your instrument panel display at night on dark roads.
  11. Sep 26, 2012 at 7:37 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ahhh I see. Makes sense. I for one like as much light as possible.. without blinding people of course. I use my projectors (older version, no foreground cutoff) plus my foglights. But that's just me.
    Thanks Pugga.
