Favorite flat black paint for Offroad rims
Discussion in 'Wheels & Tires' started by Slizzy, Sep 11, 2013.
  1. Sep 11, 2013 at 10:27 PM
    Slizzy
    Slizzy [OP] Well-Known Member
    BC Canada
    '09 MGM TRD Offroad
    Bilstein 5100's @ 1.75" front & 5100 rear, Pro Comp 7089 16x8 4.5"BS, 265/75/16 Duratracs, color matched grille, black emblem
    Getting set to paint my rims soon... What kind of paint do you guys like the most?
    I'm wanting flat black ... Spraying on stock Offroad wheels
    Would plastidip shine still?
    Primer needed? What type if so? Thx
  2. Sep 12, 2013 at 10:02 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Dip doesn't shine at all. Do you want shine? I suggest prepping the wheels with a fine scuff like an 800 or 1000 grit sandpaper or the 3M scuff pads. Then run at least 2 coats of primer followed by your color of choice. Maybe 2-3 coats of the color should do fine.
    Rustoleum and duplicolor are at a lot of retail locations (Home Depot for rustoleum). For the final coat use a clear of some sort - they make clear coats in shiny or matte finishes so there's lots of choices out there. I also read to start with the inside of the rim first then focus on the outside.
    Also here's a thread: http://www.tacomaworld.com/forum/wheels-tires/149698-how-paint-your-rims.html
  3. Sep 12, 2013 at 10:03 PM
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Also for plasti-dip on wheels I'm not sure how much it would hold up. Once you get some thickness after applying a few coats you can literally peel it off.
  4. Sep 13, 2013 at 10:07 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Rustoleum has lasted the longest out of all the top brands. I've gone thru pretty much all the big rattle can names and it's lasted the longest.
  5. Sep 14, 2013 at 1:37 AM
    Slizzy
    BC Canada
    '09 MGM TRD Offroad
    So plasti- dip is a spray ? Lol I'm such a newb... When hearing about it I'm always thinking people are actually dipping their rims in a bucket, lol
  6. Sep 15, 2013 at 2:15 AM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    plasti dip wont last as long as a well done paint job.
    but then again to replace it, its much easier than replacing the paint.
    I like the deeper black of paint and how it will last longer but theres a lot of plasti-derp fan boys around here that would love to disagree.
