Feedback on a high mileage 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbandt, Aug 21, 2015.
  1. Aug 21, 2015 at 7:48 AM
    jbandt
    jbandt [OP] Well-Known Member
    Hey folks, I've found an 03 v6 trd with 273000 miles. I'm planning on checking it out tomorrow. I do know that the timing belt/water pump/belts have been changed recently. Tranny fluid was also flushed. No major engine work has been done. i.e. no head or valve cover gaskets have been replaced. Truck seems to be in great shape from the pics. How concerned should I be with the high miles?
  2. Aug 21, 2015 at 10:55 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 TSS sport DC 4x4
    Price will be major factor.
  3. Aug 21, 2015 at 11:39 AM
    jbandt
    He's priced at blue book. I'd say it's a fair price given that most 01-04 tacoma are still being listed for over 10k (with lower miles of course).
  4. Aug 22, 2015 at 4:08 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    How much are they asking? It's always a gamble with high mileage. A clean engine goes a long way towards regular maintenance credibility in my eyes. That said, $10,000+ for 300k is :poking:.
    TACO TX likes this.
  5. Aug 22, 2015 at 8:38 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    my 00 with 183k sold for 7.5k. i wouldn't pay 5k for over 270k. If you can coax him into letting you do a compression test, I'd say base the price off the test results. if you get perfect compression in all cylinders. it's worth it. if uneven/low/combination, you'll need engine work relatively soon.
  6. Aug 22, 2015 at 9:43 PM
    jbandt
    Well it turns out that truck sold before I could see it. I did however just buy a different truck. Its a 2000 v6 4wd manual trd with almost 220000 on the clock. Truck is in decent shape. I did see that there is fluid seepage in multiple locations including rear diff, and valve cover gaskets. Right cv boot is torn. Radiator is new. ABS light is on. Its lifted and rear springs look shot. They are flat at best. I don't think timing belt has ever been done. In general it's going to need some tlc, but 5800 down from 6200 is alright in my book.
  7. Aug 22, 2015 at 9:57 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    5800 bucks doesn't seem too bad... These motors will last forever if properly maintained. An old 4Runner with a 3.4L came into my work today with 472,000 miles on it. :eek:
    I'd say go thru and do the timing belt, valve covers, and CV asap, as well as all fluids.
  8. Aug 22, 2015 at 10:42 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Yep, and I've seen an 03 Tacoma double cab with 626k, all put on by the first owner. Just amazing to think someone can drive that much, it would take me years to rack that many miles up. My 04 only has 93k on her.
  9. Aug 22, 2015 at 11:13 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    you got what i got! but i got mine at 183 or so. yes, do a timing belt a.s.a.p. and buy a couple of leafs while they're cheap. however. leafs are supposed to be flat when the full weight of the truck is on them. and get a couple of new napa shafts. that's what I did. they're awesome!
    my ABS light was on as well. i just killed the light in the console and ignored it. for off roading, you wan't full control of your brakes. No abs. or at least in my opinion. don't worry. you'll do ok. just learn how to handle a truck without ABS.
    these leafs came up for my TRD offroad 00 tacoma extended cab. check application before you buy these. they should work.
  10. Aug 22, 2015 at 11:36 PM
    jbandt
    When you say Napa shafts are you referring to new front axle shafts from Napa auto parts?
  11. Aug 23, 2015 at 12:49 AM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    Yes, new NAPA MaxDrive axles. got them on my truck. they've taken me quite far across So Cal. though they've only been on for around 10k miles. They're rated for longer too.
