Feeler/Interest gauge for 12-15 blackout interior parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cativelense, Sep 8, 2016.
  1. Sep 20, 2016 at 12:15 PM
    #601
    Cativelense
    Cativelense [OP] Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    AWWWWWWWWWWWWWWW SHIIIIIIEEEEEEEEETTTTTTT!!!!!!!!!!!!!!!!!
    Just got email notification that my stuff is supposed to be delivered tomorrow!!!!!!!!!!!!!!!!!!!
  2. Sep 20, 2016 at 12:16 PM
    #602
    ChadsPride
    Sponsored by TacomaWorld.com
    :yes::yes::yes::yes::yes::yes::yes:
  3. Sep 20, 2016 at 1:35 PM
    #603
    tacomavoyager
    tacomavoyager Well-Known Member
    Thanks again Jordan. You the man. Appreciate the extra goodies too!:thumbsup:
    ChadsPride and Cativelense[OP] like this.
  4. Sep 20, 2016 at 1:45 PM
    #604
    tacomavoyager
    And the install went well! I think it turned out great. Love the new look! Out with the chrome/gray!
  5. Sep 20, 2016 at 1:47 PM
    #605
    Cativelense
    Nuno
    CT
    Nice!!!! Any tips/tricks you found or came across while doing it?!
    EDIT: Looks like you painted your gauge cluster rings as well?!
  6. Sep 20, 2016 at 2:13 PM
    #606
    tacomavoyager
    I followed most of @nazlax10 removal for the most part. I also removed the second 10mm below the change holder. For the pins above the cluster I used a small screw driver. You push the clip in with a small amount of force. They should pull right out or fall out. They are a two piece pin so when reinstalling pull the inner pin most of the way out until flush with the top of outer pin then reinsert into cluster you should here a click. On the radio panel I had to reuse the yellow clips from old one don't forget to check yours or it won't lock into place. When swapping the ac vents there are four clips that hold them in place I used my fingernails to pry the top two open at the same time and it should pop right out. Just take your time. It was my first time pulling anything apart inside my truck. It's actually easier then it looks. Let me know if you have any other questions
    https://www.tacomaworld.com/threads...t-interior-parts.449999/page-26#post-13229954
    Used this as a reference/visual (dont need to remove airbag)
    https://www.tacomaworld.com/threads/2014-steering-wheel-control-
    install.362309/
    https://www.tundras.com/threads/paint-steering-wheel-trim-panels-on-14-15-tundra.1904/#post-89745
  7. Sep 20, 2016 at 2:22 PM
    #607
    tacomavoyager
    Thought it was the perfect time to paint them since i had the cluster off. Makes it much easier to remove the rings from the back side. i probably put way to many coats. but i think they turned out looking pretty good.
  8. Sep 20, 2016 at 2:46 PM
    #608
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    didnt ready through whole thread, but hoping someone will answer.
    will the radio surround and ac bezel fit an 09? the ac vents look the same to me so im thinking it will?
    is this only for 4x4?
    ChadsPride likes this.
  9. Sep 20, 2016 at 3:16 PM
    #609
    starforsaken
    starforsaken Well-Known Member
    Star
    Tucson, AZ
    2015 MGM DCSB OR
    20160920_151218a.jpg My goodies arrived today. :woot:Though, I will probably wait until the weekend to install so I have enough time to do everything right.
    Thanks so much for the excellent service Jordan @Titus_Will_Toyota.
  10. Sep 20, 2016 at 3:16 PM
    #610
    99TacoDriver
    South Louisiana
    so this will fit in the older 2nd gens?
    i have an 09 with a double din radio( not stock) so id be able to get the ac bezel and im guessing id need the radio surround that fits the 13's too?
  11. Sep 20, 2016 at 3:49 PM
    #611
    Cativelense
    Nuno
    CT
    Sweet. Nice job man. Looks awesome. Can't wait to get my stuff to dobit all, and then wait for the 4x4 switch and ring to finish it off!
  12. Sep 20, 2016 at 3:59 PM
    #612
    Cativelense
    Nuno
    CT
    I think if you upgrade(d) to the newer years radio (12-15) it will. Not 100% sure though.
  13. Sep 20, 2016 at 5:01 PM
    #613
    Justified
    Justified Well-Known Member
    Wayne
    Nevada
    2023 MGM 4x4 TRD Off Road
    On your steering wheel controls, are the new ones the same as the old ones as far as buttons? Do all the new buttons work? I'd like to have the upgraded controls for my 2013 but I don't know if they swap over.
    Not my picture but my truck looks the same.
    Quakes15 and ChadsPride like this.
  14. Sep 20, 2016 at 5:12 PM
    #614
    99TacoDriver
    South Louisiana
    We'll I was thinking it'd work because I don't have a stock radio. I got a pioneer head unit so I'd just need a dash kit for the double din radio.
    Another question: are these only available for 4x4 models?
    I don't have a 4x4 truck.
    If not then I'd be willing to buy someone's old ac bezel. The silver one
  15. Sep 20, 2016 at 5:21 PM
    #615
    tacomavoyager
    The ones pictured are the same as my old ones. Its basically plug and play. The only functions that don't work are left arrow,right arrow, voice command and it lighting up. The left and right arrows are not necessary for our stock radios and neither is the voice command. It not lighting up is not a big deal to me. but eventually might look into making it work.( i believe it just needs an extra ground?)
    Justified[QUOTED] and ChadsPride like this.
  16. Sep 20, 2016 at 5:45 PM
    #616
    Cativelense
    Nuno
    CT
    I think the ac bezels all have the cut out for the 4x4.
  17. Sep 20, 2016 at 6:00 PM
    #617
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Wait till we get our Hiluxs installed dude then they will be the Jelly ones!!! :bikewheelie2:
  18. Sep 20, 2016 at 6:01 PM
    #618
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    I would assume that since these panels are from the base model tacomas, and base of bases doesn't have 4x4, there should be a panel without 4x4 opening. Right @Titus_Will_Toyota?
  19. Sep 20, 2016 at 6:06 PM
    #619
    starforsaken
    Star
    Tucson, AZ
    2015 MGM DCSB OR
    I bought the AC bezel without the opening. I also bought a matte black radio bezel to match. I wont be attempting the swap until this weekend, but name your price and the silver AC bezel and the black pearl radio bezel are yours.
  20. Sep 20, 2016 at 6:25 PM
    #620
    tacoma909sport
    tacoma909sport Well-Known Member
    So Cal
    14 DoubleCab Sport
    is this deal still going on?
