feeler: trade my 1st gen buckets for you bench
Discussion in 'Buy / Sell / Trade' started by matthew5olson, Jan 12, 2010.
  1. Jan 12, 2010 at 4:33 PM
    matthew5olson
    matthew5olson [OP] Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I have a 2004 ext cab with bucket seats. Both are in good condition. I will clean them for you before I would trade. I would like to see if someone has a 60/40 bench they wanted to trade. does anyone know if they would bolt right on. I would imagine the worst case senario would be putting extra bolts through the floor. I would give you the center consol too. It would ave to be a meet and swap. Its my dd and I can't ship my seats.
    not mine but they're the same ones so you get the idea.
  2. Jan 12, 2010 at 4:39 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    I would so do this if I lived closer. I've been looking for buckets but they were all like $500 fore a used pair from an junkyard. plus a bench makes it easier for road head.
    thats really why idecided against it. and now i know my next truck has to have a bench :D
  3. Jan 12, 2010 at 4:44 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I've done the bench to bucket swap. All first gens will bolt right in, no problems. I put 04 buckets into my 97. Only problem I had was the seat bolts were rusted in pretty good. I broke a couple and had to drill and tap.
  4. Jan 12, 2010 at 4:48 PM
    matthew5olson
    matthew
    pittsburgh, PA
    Anywhere close to boston? My aunt works out there now as a flight attendent and might need me to take some stuff out there.
    I'm acustomed to driving a whole day for stuff. I put over 50k a year on my truck. How comfortable are the bench seats. my buckets make my butt numb after 4 hours of driving. I have to have those wooden beads underneath my seat cover or they are unbearable on long trips.
  5. Jan 12, 2010 at 5:08 PM
    oofy15354
    Dave
    Massachusetts
    actually I'm a half hour south of Boston but I'd have no problem meeting you if we found a mutually acceptable time.
    I only have the full bench, not the 60/40 but if your looking for a change from the buckets, thats what you want. the 60/40 still has a bucket on the passenger side basically.
    The longest trip I've done was 4 hours and it didn't seem too bad. I liked it better than the buckets in a Matrix. You have more freedom to move and adjust your position but I do miss an arm rest on the right. I usually drive right handed but it was awkward when i wasnt cause i didn't know where to put my hand.
    Theres a bit of extra padding that was added to the drivers side but it could easily be added to the passenger side. its just a strip of foam that makes the right shoulder part come out a bit more. more could be added.
    since you have the extended cab, you should know that the back isnt fully covered with the yellow foam exposed (easy to add more but kinda ugly)
    im not trying to sway you either way cause i do but dont want the buckets (for reasons above) but if your interested, let me know and well work it out
  6. Jan 12, 2010 at 5:19 PM
    matthew5olson
    matthew
    pittsburgh, PA
    There's no fold down armrest on the full bench? I guess it wouldn't be hard to make a box and put some padding on it for an arm rest. I have a stick and so I drive with my left. I like to rest my wrist on something with my hand on the shifter.
    I partially would like a bench because I sleep in my truck often and I think a bench would be lightly more comfortable. Currently I am forced to sleep in one of the seats with them reclined as far back as they go but my neck always hurts in the morning. It hard to lay longways in the truck because the seat belt things stick out and the center consol is a hard plastic. The 60/40 bench has a bucket but its flat correct? the ends don't curl up like a true bucket?
  7. Jan 12, 2010 at 5:30 PM
    oofy15354
    Dave
    Massachusetts
    Heres a stock Image of the 60/40
    I've always heard it is a true bucket but its hard to tell from the pic and ive never seen one in person
    Heres what I have:
    but not nearly as raggedy plus mine a bit more styled as its from an '04 not the earlier models (95-99)
    im not sure about how far they recline cause i have a reg cab but they fold down almost flat so id assume they go back too. (actually now im not sure. they may fold down but only lock in 1 upright position.) itd still make for a better bed sideways
  8. Jan 12, 2010 at 5:38 PM
    oofy15354
    Dave
    Massachusetts
    if you actually want pictures and specs ill check it out tomorrow. its damn cold out right now and im quite comfortable without pants on
  9. Jan 12, 2010 at 5:42 PM
    matthew5olson
    matthew
    pittsburgh, PA
    your's only locks in one upright position? as in it doesn't recline back at all?
    my father in law had a 60/40 split in his 97 ext cab he said it reclined pretty far.
  10. Jan 12, 2010 at 5:46 PM
    matthew5olson
    matthew
    pittsburgh, PA
    that's fine. I'll grab a pic of mine too. I'll try and find a local one to see too. that way I can get an idea of what they can do and stuff.
  11. Jan 12, 2010 at 5:49 PM
    oofy15354
    Dave
    Massachusetts
    im not positive. ill check tomorrow. i dont remember ever adjusting it. it probably goes back, it just doesn't lock. ill try to give you an answer by like 4 tomorrow if you want.
    no pressure either way. im happy either way. i just dont want you to regret it later on
  12. Jan 12, 2010 at 10:20 PM
    matthew5olson
    matthew
    pittsburgh, PA
    bump. anyone have 60/40
  13. Jan 13, 2010 at 7:12 PM
    oofy15354
    Dave
    Massachusetts
    yeah mine doesnt fold back. it only locks in that one position so that doesnt sound like what you're looking for. if it still is and you want pictures let me know
  14. Jan 10, 2011 at 11:06 PM
    TacoStand
    TacoStand Active Member
    Denver
    00' Supercharged Xcab
    I would do it in a heartbeat if we could work it out.
    if you are any where close to CO let me know.
