Feeling Unstable
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomattack, Aug 19, 2019.
  1. Aug 19, 2019 at 4:14 PM
    tacomattack
    tacomattack [OP] Well-Known Member
    New member here. I have a 2017 TRD OR in blue. I just updated my tires to a 265/75/16 on TRD Pro wheels. No lift and no mods to the suspension.
    Here is my issue...I am getting an odd shake/wobble at speeds over 60. I recognize that I did increase the truck’s height by .5 inch, but did not expect this. Has anyone else felt this after a similar mod?
    Any thoughts or advice would be appreciated.
    JP
  2. Aug 19, 2019 at 4:20 PM
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    things to check:
    Is tire pressure the same in all tires ?
    Are the lug nuts torqued to the correct spec?
    Best bet is to go back to place that installed tires and ask them to rebalance.
  3. Aug 19, 2019 at 4:20 PM
    su.b.rat
    su.b.rat broken truck
  4. Aug 19, 2019 at 4:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah what he said ^^^ My guess is they're not balanced properly, but tire pressure is a great place to start.
  5. Aug 19, 2019 at 4:23 PM
    eon_blue
    Azusa, CA
    First thing I'd be doing is checking those lug nuts to make sure some tech didn't get distracted or something and forget to torque all of them down. Happens way more often than you'd want to think. Never assume that someone working on your truck is going to care about it as much as you do, I always check the lugs after getting tire work done.
    If that checks out, take it back to them and describe the issue...most likely a balancing issue. KO2s are good tires but some people report having a lot of trouble getting them balanced (I never did but I read about it on here time to time)
    auskip07, wilcam47, c0climber and 3 others like this.
  6. Aug 19, 2019 at 4:33 PM
    tacomattack
    So just checked and on cold(ish) tires. The pressure is 40 on both fronts, and 41, passenger rear and 43 on driver rear. I’ll correct that ASAP.
    _gray_knight_ and EatSleepTacos like this.
  7. Aug 19, 2019 at 4:33 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Try like 33 front and 31 rear and go from there. If you wanna get fancy, do a chalk test.
    Mr-Paul and RobP62 like this.
  8. Aug 19, 2019 at 4:34 PM
    eon_blue
    Azusa, CA
    If those are E rated KO2s then 40+ psi is going to make them ride like bricks, ask me how I know lol. Then again my truck is lighter than the 3rd gens but I would think ~32 psi would be better
    Mr-Paul and Stocklocker like this.
  9. Aug 19, 2019 at 4:34 PM
    tacomattack
    Wow. That’s far from where they set them.
    RobP62 and EatSleepTacos[QUOTED] like this.
  10. Aug 19, 2019 at 4:35 PM
    tacomattack
    Yes, E load.
  11. Aug 19, 2019 at 4:35 PM
    eon_blue
    Azusa, CA
    My tire shop put mine at 55 psi when they installed them, don't give those guys too much credit haha. They're just trying to crank out jobs and often aren't considering the details of each vehicle they're working with tires on. And keep in mind the suggested PSI on the door jamb is for the stock tires which are much lighter than E rated ones, so those suggested numbers won't apply
    2BeersPlease and Shellshock like this.
  12. Aug 19, 2019 at 4:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep. Try and that and double check the lug nuts as suggested above and go for a drive. If you have a torque wrench it wouldn't be a bad idea to crack them loose and retorque, one at a time, to save yourself potential future headaches if they over tightened them.
    DrFunker likes this.
  13. Aug 19, 2019 at 4:39 PM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    Lug nuts. Tire pressure. Balance. Yep that pretty much covers it.
    c0climber and camillethetoy like this.
  14. Aug 19, 2019 at 4:42 PM
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    Tire pressure, lugs are tq down correctly and weights are still on the wheel if used. The hellwig sways are great but in this case the sways wont help with the light trembling you're experiencing.
    TacoJova likes this.
  15. Aug 19, 2019 at 4:44 PM
    Bkenny311
    Bkenny311 Active Member
    2019 Cement TRD Sport Tacoma
    Definitely try to have them rebalanced
  16. Aug 19, 2019 at 4:47 PM
    tacomattack
    Thanks everyone. The install came with lifetime balancing, so I don’t anticipate any issues.
    Something I should have added in my original post, if I go over a couple bumps at speed (60+), it’s borderline unsafe.
  17. Aug 19, 2019 at 4:48 PM
    eon_blue
    Azusa, CA
    That sounds like how mine felt when the tires were overinflated...hitting small bumps on the freeway made the rear end especially feel like it was going to jump sideways on me. Bringing the PSI down helped a ton.
    Mr-Paul likes this.
  18. Aug 19, 2019 at 4:52 PM
    BrokeDownSouth
    BrokeDownSouth Well-Known Member
    Chase
    2019 TRD Off Road Super White
    Chalk test? Please explain.:threadjacked:
    RobP62 likes this.
  19. Aug 19, 2019 at 4:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  20. Aug 19, 2019 at 4:54 PM
    tacomattack
    Aside from these issues, the tires are WAY better than stock. People kept saying it would be a rough ride, but I haven’t noticed it...obviously aside from the issues detailed above.
    eon_blue likes this.
