Feels like warped rotors BUT intermittent?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco47, Sep 29, 2016.
  1. Sep 29, 2016 at 3:48 PM
    Taco47
    Taco47 [OP] Well-Known Member
    Norcal
    2016 2TR 5-Speed
    I'm thinking my rotors are warped because my steering will shakes when braking from highway speeds. My concern is
    1) it's intermittent and 70% of my braking is shake free. Keep in mind this calculation only accounts for breaking at highway speed and I don't feel anything under 50 mph.
    2) I thought warped rotors should cause a pulsating feedback from the brake pedal, I feel none.
    3) the shakes are more prevalent on the days following a tow but the symptoms decrease significantly in short time.
    I've never warped rotors before but I expected that once warped, its warped. I have a set of EBC rotors and pads on the way but if you guys think my problem is anything else let me know, thanks.
  2. Sep 29, 2016 at 5:22 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Check that your callipers aren't seized. I have the same issue but mine, according to a mechanics opinion of my description, is that the calliper is rubbing all the time and with the added friction the rotor warps temporary. Mine seem to have to heat up to a point then I get the Michael J. Fox's.
    Taco47[OP] likes this.
  3. Sep 29, 2016 at 6:04 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    Taco47[OP] and Jimmyh like this.
  4. Sep 29, 2016 at 9:26 PM
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    Check your pads first, my buddy has an '03 Runner, took it to a shop about a year back for pads & regular service, about 3 months later, damn things had snapped right in half, causing some nasty shake and a slight rattle.
  5. Sep 29, 2016 at 9:29 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Any chance you're experiencing torque convertor lock up shudder ?
  6. Sep 30, 2016 at 12:05 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You are getting brake pad material deposited on the rotors when towing. That is what causes the shuttering. Read the link Taco Pete posted above. Good info there.
  7. Sep 30, 2016 at 12:41 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2 - I changed my rotors and pads and still had the shakes - just recently change the caliper rotor and pads on the one side that was worn - problem solved.
  8. Sep 30, 2016 at 1:51 AM
    CodyTaco
    CodyTaco Well-Known Member
    Cody
    2013 dcsb sport spruce
    ^ good info there.
    The other thing to consider is, if your rear brakes are shot or not properly adjusted. You may be getting close to %100 of your braking force to the fronts. Tacomas rotors don't have much material and heat up very fast. Causing uneven deposits. Little or no back brakes would make it even worse.
    One panic brake takes me a week of smooth braking and trying to re bed my rotors to smooth them back out.
  9. Sep 30, 2016 at 9:38 AM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    I have a similar problem. I feel mild shaking from all stops, but once on the freeway after a few braking periods (like going down a hill) I'll have extreme shaking.
    guess I'll have a look at the calipers, thanks!
  10. Sep 30, 2016 at 2:17 PM
    maintenancefreak
    maintenancefreak Well-Known Member
    sal
    port st. lucie fl.
    trd sport
    yep.. just put knew ones on mine
  11. Sep 30, 2016 at 2:31 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Brake deposits on the rotors.
  12. Sep 30, 2016 at 3:32 PM
    Mighty Casey 19
    Mighty Casey 19 Well-Known Member
    Casey
    Orange County, right near the beach and the mouse
    2012 Silver Streak Mica dbl cab TRD pre runner
    Tri-Fold by Undercover
    I had the same shake. 90% of my driving is in stop and go LA traffic. If i was over 50MPH, braking would give a shudder so bad, if i took my hands of the wheel it would turn left to right about an half inch. As I came to a stop, the shake would become less noticeable. I changed pads and rotors and my issues is gone. I searched a for days for a definitive answer, but read a lot of what you are reading here. Seems like multiple issues may be a cause.
    Pads and rotors solved my issue, but could be more to the puzzle.
