Fellow 2010 Owners please help...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeff3004x4, May 28, 2010.
  1. May 28, 2010 at 4:16 PM
    Jeff3004x4
    Jeff3004x4 [OP] Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    Ok what is the difference between 2010 vs 2009 in the exciting world of aftermarket trailer wiring harnesses? I bought one at work today (Valley) for a 2009 thinking the vehicle application list just was not updated and it would fit. So far it is looking bad, my kit has two pig tails with 6 prong connectors and my truck only has one connector and it is 4 prong. I think I traced the wiring back as far as I can, I do not see any more connectors. Anyone put an aftermarket kit on their 2010?
  2. May 28, 2010 at 4:18 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Nope mine came stock with the tow package:D
  3. May 28, 2010 at 4:19 PM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    Bah! Does your truck have 4 wires going into the back of the OEM connector, or 6? I want to tow my boat Sunday and the OEM kit is on back order until the 2nd, who knows when I will get it.
  4. May 28, 2010 at 4:32 PM
    JCM_Buford
    JCM_Buford Member
    JC
    Buford, Ga.
    PreRunner Off-rd pack
    How heavy is the boat trailer and does it have brakes?
    If not, then you should be able to convert from the trailer to a standard four plug without much difficulty.
    If however you boat trailer has brakes, then the additional wiring is needed for the brake controller.
    If no brakes on the trailer, find the wiring harness, plug in the 4 pin connector to the truck and then start testing the other lines to match left turn, right turn, brakes and running lights.
  5. May 28, 2010 at 4:56 PM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    The boat is 500lbs soaking wet. I cannot find the two plugs under the truck. Basically I have the 4 prong harness that is "plug and play" but I can't find the plugs to plug it into. I'm pretty smart with cars, I have searched high and low under the truck I cannot find the two plugs. The instructions say 6 - 12 inches from the back bumper. I only find one plug that seems to be for the license plate lights, which is too small for the plugs on my valley harness. Is 2009 different than 2010? Do I have to take the tail lights off to find these two plugs? I'm at a loss, maybe I'll be waiting for my OEM one from Toyota...
  6. May 28, 2010 at 5:43 PM
    Slick10
    Slick10 Member
    Bill
    Rockwell, NC
    10 SR5 4 cyl. 5 speed Barcelona Red
    Undercover, Color matched Satoshi, Fog Lights, Tailgate lock, locking bed compartments.
    You need to remove the tail lghts, the connectors are right there.
  7. May 28, 2010 at 5:54 PM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    REALLY! NICE! I know what I'm doing tomorrow after work. Thank you! The Valley instructions mention no such thing.
  8. May 28, 2010 at 6:02 PM
    Slick10
    Slick10 Member
    Bill
    Rockwell, NC
    I know what you mean, I had to learn the hard way. Took half of the truck apart before I figured out where the connectors were.
  9. May 28, 2010 at 6:05 PM
    Jeff3004x4
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    Omg this is awesome I found the instructions for the factory hitch harness online, FUCK THAT, this kit is so much simpler. But it's dark now and I don't have a garage so I have to wait until tomorrow to install the kit.
  10. May 28, 2010 at 10:27 PM
    JKD
    JKD Well-Known Member
    I found that the wire that runs to the passenger side is just barely long enough on the trailer wiring adapter I bought. I think the 09+ trucks have those connectors further outboard on the wiring harness.
    It worked, but I sure would have liked to have had about three more inches of wire for some slack.
