fender well trimming
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigdaddytaco, Mar 21, 2011.
  1. Mar 21, 2011 at 5:25 PM
    bigdaddytaco
    bigdaddytaco [OP] Well-Known Member
    jared
    sylva nc
    2000 tacoma
    ARB bumper 3 inch oldman emu lift piaa fog lights
    could anybody tell me or lead me to a thread that will show me the right way to do this with no metal cutting
  2. Mar 21, 2011 at 7:48 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Got any pics ?? With a 3" lift why do you need to trim fenders if I may ask ?? :notsure:
  3. Mar 22, 2011 at 3:01 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    what size tires are you making room for? do you just need to do the pinchweld mod?all ya need there is a BFH, no metal cutting.
  4. Apr 11, 2011 at 8:18 PM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    tryen to fit 33-12.50-15
  5. Apr 11, 2011 at 8:24 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Here's what I did for my 33's
    Crom likes this.
  6. Apr 11, 2011 at 9:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    :confused::confused::confused::confused::confused::confused::confused::confused: ^^^^^^^^^^^ How does this help the OP?
  7. Apr 11, 2011 at 9:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What wheel you got those big meats mounted on? Stock rim? 15x8? 15x10?
  8. Apr 11, 2011 at 10:52 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    OP some pictures of your truck and sizes of wheels would help us out a little more... i didnt lift my truck but did need some trimming done, I used a cutting wheel on a grinder to cut them back a little bit
  9. Apr 11, 2011 at 11:02 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    X2 thats exactly what i did to fit 33's..
  10. Apr 12, 2011 at 12:30 PM
    Blacktacoma23
    Denver/Phoenix
    I was just showing him what I did, just trimmed some plastic no metal cutting.
  11. Apr 12, 2011 at 12:35 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  12. Apr 12, 2011 at 12:43 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah i have 33x12.5's on my truck we need to know the wheel you plan to use to determine what you have to cut. Also what size lift you have
  13. Apr 12, 2011 at 8:11 PM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    my wheel is a 15-8 or 15-7 and i have a 3 inch lift with a 2 inch leveling kit (just because the ARB bumper and wench) im looking to get wrangler duratracks if that helps
  14. Apr 12, 2011 at 8:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Is that a 2" spacer on top of an OME coil spring with a OME nitrocharger strut? Whats in back? Blocks? Are you a 4x4?
    Wow man, you go some pics of that setup?
  15. Apr 12, 2011 at 8:32 PM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    ya i basically have 2 inch blocks on the front not enuf to tell i have blocks tho
  16. Apr 12, 2011 at 10:43 PM
    Blacktacoma23
    Denver/Phoenix
  17. Apr 13, 2011 at 4:51 PM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    that's what i need thanks man that tells me why i could never find any plastic to trim
  18. Apr 15, 2011 at 9:48 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    I always find it funny when 2nd gen people post in the 1st gen section thinking they can help :p
  19. Apr 15, 2011 at 9:53 PM
    Camo23
    Camo23 Well-Known Member
    Drew
    Fallbrook, CA
    08 DC 4x4
    Not much yet
    x10000000
  20. Apr 16, 2011 at 10:57 AM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    has any body on here done that to there truck
