Few camburg Spindles questions
Discussion in 'Suspension' started by SoCalBlack08, Nov 7, 2009.
  1. Nov 7, 2009 at 3:46 PM
    SoCalBlack08
    SoCalBlack08 [OP] Well-Known Member
    CA
    08 PreRunner DC
    ok so i know i can run the spindles with my stock coils and shocks but is it better to get new shocks in the front or is the ride not that bad?
    in the rear will 1500's work and how bad of an idea is it to use a 2" aal and 2" blocks?
    do i need brake lines for the back or is it just the front?
    and last how much do u think it will cost to have them installed?
    i have a $3000 dollar budget but that has to include the rims and tires which will run about $900.
    thanx!:)
    pix welcome:D
  2. Nov 7, 2009 at 4:31 PM
    socaltaco2
    socaltaco2 Active Member
    you have 2wd right?
    4" Lift in the rear will be too much lift. 2"-3" MAX. I could be wrong but I dont think you need new shocks in the front since it retains stock suspension geometry.
    not sure about brakelines, but id excpect to pay between 300-600 for install of spindles
  3. Nov 8, 2009 at 2:28 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    I have 2.75 inch leaf springs on my truck and I dont need extended brake lines in the rear. Anything more than 3 inches in the rear and you will start to sacrifice performance for looks.
    With spindles up front you don't need new shocks but you will need extended brake lines up front which should come with the spindles. And I think I payed $350 to have my spindles installed.
  4. Nov 9, 2009 at 12:07 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    well i have a 2008 so i might be able to get the tsb done so should the tsb and tsb aal give me enough lift to match the 4'' front?
  5. Jan 4, 2010 at 10:12 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    no for spindles 4" in the front is not too much! coilovers at 4" is way too damn much if even possible
    install 300 bucks or 7 hours of your time
    comes with extended brake lines, only need them for the front. 2" or tsb should level it out nicely
    if anyone reads this: can i run my stock wheels with the camburgs without any rub?
  6. Jan 5, 2010 at 7:21 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    i would call camburg about that, with my engage spindles i need a minimum of a 4.5 bs.
  7. Jan 5, 2010 at 11:18 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i'd at least slap on some 5100's up front with that spindle and match them out back. i like those lift spindles, wish they made them for the 1st gens
  8. Jan 5, 2010 at 1:21 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Might help with some down travel and better ride quality but I don't know for sure.
    Yes
    It's been said on this forum several times, never stack lifts...I don't know if this applies to the rear or not, but it just sounds like a bad idea. Plus I think it would be too much lift in the back. A 2" ALL should be fine.
    Don't know sorry :(
    As much as someone can charge you; shop around for install pricing, or save the money and do it yourself if you have the tools and time. 08pretaco and I did his with help from my dad and I bet we could get you going if you wanted to call either one or both of us. But I think I have heard in the neighborhood of $300-$600 for install.
    Holy crap...um so my info cost $500, and yes i take checks :D. Seriously pay up already...
    No problem bud that's what an online community is for ;)
