Few problems, need some help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hawaiian5.0, Jul 19, 2012.
  1. Jul 19, 2012 at 10:35 PM
    Hawaiian5.0
    Hawaiian5.0 [OP] New Member
    Hilo, Hawaii
    3" Revtek w/ add a leaf
    Got a prob guyz, need your expertise as I'm not real familiar with these trucks. Baught new 07 4dr, 4X4 TRD off road package, automatic, with 71K miles. Installed a 3" Revtek kit plus add a leaf in rear, 16X8 wheels on stock size Toyo A/T's.
    Probz I have are:
    Have a driveline vibration from approx. 55 to 69mph, fine over or under those speeds. Most of it goes away when it's kicked into 'N". Tried shimming the center support bearing from one shim to over 1.5" with no luck. Any ideas?
    HVAC fan only blows on high. FOUND THE FIX
    Overhead compass/therometer quit working. FOUND THE FIX
    Any help would be greatly appreciated! Thanks guyz!
  2. Jul 20, 2012 at 5:32 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Bad U joint?
    Did this happen after you raised it?
  3. Jul 20, 2012 at 6:07 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Some people have the driveline vibration after putting in the AAL. You might try the 3 degree axle shims from Toytec.
  4. Jul 20, 2012 at 6:38 AM
    BamaToy1997
    Bill
    Navarre, FL
    This is a good idea. The trick is first finding the cause of the vibration before you put parts in it. Saves money in the long run. I have heard of some driveline vibrations coming from diff angle, to driveshaft issues, carrier bearing issues, etc. Finding the problem is the hardest part.
    The most interesting part is that your vibration is between 55-69 MPH, which happens to be the exact speed range that an out of balance tire will vibrate at, causing a similar problem.
  5. Jul 24, 2012 at 1:30 PM
    Alby22
    Alby22 Well-Known Member
    Ashville, Ohio
    Cement 2020 Toyota Tacoma TRD Sport 4x4 Double Cab, Long Bed
    My compass and temp readout stopped working also. What did you find to be the problem with yours?
  6. Jul 24, 2012 at 8:12 PM
    Alby22
    Ashville, Ohio
  7. Jul 24, 2012 at 8:23 PM
    Alby22
    Ashville, Ohio
  8. Jul 26, 2012 at 8:53 PM
    Alby22
    Ashville, Ohio
    PA-POW! The process worked like a charm. One of the 510's was loose and kicked up. I gently pressed it down, and added a small amount of solder. Plugged everything back in, and back in business! Thanks again, Tacoma World
