Filling the tailgate gap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BKinzey, Apr 12, 2017.
  1. Apr 12, 2017 at 10:54 PM
    BKinzey
    BKinzey [OP] Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Have a cap on my truck and one of the uses is for camping.
    I've noticed at the tailgate/ bed there are gaps. Driving down dusty roads and I get quite a bit of dirt/dust drifting into the bed area.
    I'm thinking adding some rubber seals and wondering if anybody else has addressed this problem?
    Thanks.
  2. Apr 12, 2017 at 10:57 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
  3. Apr 12, 2017 at 10:58 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    IronPeaks Forest Road Cruiser Build
    Attempted to seal the tailgate against dust. I used these 2 things, hasn't been long enough to know if they work well/stay applied.
    edit, 3 months in , so far so good. the top portion of the seal where it "folds over" a bend has come unstuck, but that's all.
    [​IMG][​IMG] i
    TireFire, scocar, tomwil and 2 others like this.
  4. Apr 14, 2017 at 9:01 AM
    BKinzey
    Beauford
    Hollywierd, CA
    Thanks for the suggestion IronPeak. Just ordered the tailgate seal. I'm also going to use it instead of the Rok Block as I don't think I want to "attach" the tailgate to the truck.
    IronPeak likes this.
  5. Apr 14, 2017 at 9:13 AM
    Pigpen
    Dan
    Northwest Montana
    I used pieces of the adhesive strip that seals the topper to the bed rails.
  6. Apr 14, 2017 at 12:05 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Let me know how you make out, i too am tired on my bed getting filthy. I have a LEER cap and is usually empty, it always gets dusty and dirty back there.
  7. Apr 14, 2017 at 12:14 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  8. Apr 14, 2017 at 3:17 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Regular old foam weatherstrip(adhesive on one side) works fine and costs <$10 a roll. I replace it every two or three years if I feel like it. You generally want the thinner(aprox 3/8" width) to help go up the side of the bed/tailgate and at least 1/2" height.
  9. Apr 18, 2017 at 1:37 PM
    BassAckwards
  10. Apr 18, 2017 at 3:55 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Installed the tailgate seal and looks like it will work out well. Wonder about the "stick on" aspect, if it shows any sign of peeling I'll use silicone to reattach.
    I removed the tailgate to make installation easier and I had a little problem re-installing the wiring for the back-up camera. Just kept working and wiggling to get the plastic bracket behind the seal and it worked.
    BassAckwards likes this.
