Filter Magnets?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoSupreme, Jan 1, 2008.
  1. Jan 1, 2008 at 7:15 PM
    TacoSupreme
    TacoSupreme [OP] Well-Known Member
    007 DC Cuatro Por Cuatro
    Anybody using filter magnets? If not, check it out here filtermag.com
  2. Jan 1, 2008 at 8:03 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    what about those magnetic oil pan plugs? would those be any good or another waste?
  3. Jan 1, 2008 at 10:46 PM
    ERdept
    ERdept Well-Known Member
    A cheap solution is to get those super powerfull Neodyneum magnes off ebay and just stick it to the bottom of the oil pan.
    Makes, whatever passes by stick to it. Just keep it there.
  4. Jan 2, 2008 at 6:01 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    I've used a magnetic plug before (GM engine) and there was always plenty of metallic debris when I changed the oil. It's not just for bearing shear but all moving parts. Anything inside the engine is going to lose microscopic size particals from friction over time (most noticably during the first 1000 miles). I don't know how much of the internals will be effected by a magnet but I do know that when I changed my oil in my '08 Taco at 1000 miles (as I do with ANY vehicle) it left PLENTY of metallic debris on my oil collector.
    I clean the pan between every oil change and look for this type of residue. For the first couple oil changes, but mostly so on the first, I find the previously clean black plastic looks like it was painted with a metallic paint. Wipe it with a nice white cloth and you can see the accumulated metal particulate on the rag. I haven't thought to try a magnet against the debris yet but you bet I will at the next change.
  5. Jan 2, 2008 at 6:43 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    I have a magnetic plug in the oil pan of my 57 Chevy and it picks up a lot of stuff! ! I not so sure that I want to see all of that stuff:) I would be just as happy to let the filter take care of that! !
    HAPPY NEW YEAR
    Don G
  6. Jan 2, 2008 at 9:58 AM
    cvillechopper
    Charlottesville, VA
    The problem with letting the filter take care of it is that it restricts oil flow. The more you can stop before the filter, the less it effects flow. With older paper filters, the debris could actually rip the filter element if it got clogged enough. I had that happen on my '76 Nova. You could actually see a small hole on the inside of the filter. Doesn't really make that much of a difference when you've got a rust-bucket 305 jacked up with air shocks and blowing smoke, but I wouldn't want my Taco to have anything circulating that shouldn't be.
  7. Jan 2, 2008 at 10:36 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Yep!
    4 magnets $7 shipped. You could probably just stick one on the head of the oil drain plug.
  8. Jan 2, 2008 at 10:41 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Linky no worky... :(
  9. Jan 2, 2008 at 11:02 AM
    Evil Monkey
    Robert
    Escondido, CA
    Fixed it.
