Filters
Discussion in 'Photography' started by asphaltpilot, May 6, 2013.
  1. May 6, 2013 at 1:13 PM
    asphaltpilot
    asphaltpilot [OP] CAPS CAPS CAPS!
    South Florida
    PreRunner SR5
    Are they worth it? Do they provide any benefit that could not be achieved with post-processing (or in camera) software? Any particular ones you'd recommend?
  2. May 6, 2013 at 1:27 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    I'm confuserd? Filters as in Camera , or as in KN Filters?
  3. May 6, 2013 at 1:28 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Definitely worth it. They are pre-processors in a sense. I would have a UV and polarizing filter at least, if my camera could use em.
    He means camera, hence the photography section.
  4. May 7, 2013 at 2:52 AM
    JawKnee
    JawKnee I <3 Pink Tacos
    Ontario Ranch
    2002 Tacoma
    Total Chaos, DMZ, Deaver, Sway-Away, KMC, BFG, Hella, ICOM, BTF, Glassworks, Trac Performance, Lowrance.
    I just started using an ND filter and what a difference! It helps so much when your shooting mid-day and want to shoot wide open to get nice background blur.
  5. May 7, 2013 at 7:46 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I keep a polarizing filter on my 50mm at all times.
    If only for the cheap protection it gives the lens.
  6. May 7, 2013 at 8:07 AM
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    Filters are cheap cheap insurance for the lenses. My wife always has a UV filter on her lenses. She has some other filters that help with shooting through reflective surfaces ie glass and stuff like that. The things they can do when used correctly are amazing.
  7. May 7, 2013 at 8:16 AM
    97Blk_one
    Memfrica
    not so low
    Sorry...hook'd on phonic does't wurk for me...:D
  8. May 7, 2013 at 12:48 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    always. i never use the lens cover. i just filter it up, and go.
    i had a UV filter on my Leica. great protection.
  9. May 7, 2013 at 9:52 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    maybe its just me, but i read this as a question about creative filters...
    i got my start in photography before digital, and we used Cokin Classic P Series filters on medium format and 35mm film cameras...
    in today's digital age, especially with one stop programs like Lightroom, it may not be worth the added expense to stock up on these on camera systems...
    much of what you can do is achieved in post production and with the use of layers, you can create some great final production artwork...
    you can find used filter systems online i'm sure, so if you have the cash and time, i say experiment with them and see what you can learn from the fundamentals of image capture with no digital manipulation...
  10. May 7, 2013 at 10:11 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Every lens on every camera I've ever owned that accepted add-on filters has had a UV/Haze filter installed from before it left the table when removed from the box.
    Circular polarizer is good to have, but be careful, if shooting wide angle, the sky will get funky because the polarization changes as the field widens and you'll get dark/light areas.
    Diffusers can be fun for portraits and other special effects.
    Grads are useful if not overused. If in doubt, don't use a grad. They are good if you have an exceptionally bright background (like shooting into a sunset) and allow you to capture foreground detail that would normally be blacked out.
    Another fun one is the "star"... love/hate among hobbyists, but they have their place. I have a 4/6/8 "ray" set.
    Back on the polarizing filter....
    The only difference between these two shots is the position of the polarizer.
    I totally forgot that I had the polarizer until after taking the first shot (I had taken about 15 shots of the shrine up to that point).
  11. May 8, 2013 at 8:44 AM
    asphaltpilot
    South Florida
    PreRunner SR5
    Thanks for the input.
    I'm thinking about buying a couple to give them a try. I especially like things I've been reading about ND filters, such as allowing for longer shutter speeds in daylight. I also want to get some beach photos but am pretty petrified with exposing my camera to those elements.
