Filthy Engine Bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rakso, Mar 26, 2011.
  1. Mar 26, 2011 at 12:52 PM
    Rakso
    Rakso [OP] CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Any suggestions on how to clean this?? Thanks.
  2. Mar 26, 2011 at 1:02 PM
    TUVAI
    TUVAI Active Member
    Polynesia
    07 DC TRD
    MBRP
    super clean
  3. Mar 26, 2011 at 1:05 PM
    Rakso
    Rakso [OP] CeRaTi
    OsKaR
    Cali
    09 PreRunner
    That's how I want it to be! :D
  4. Mar 26, 2011 at 1:07 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    take a couple bucks and go hose it down at the car wash.
  5. Mar 26, 2011 at 1:10 PM
    Rakso
    Rakso [OP] CeRaTi
    OsKaR
    Cali
    09 PreRunner
    ummmm :rolleyes:
  6. Mar 26, 2011 at 1:11 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    if its still dirty after this, use warm water at your house. try to avoid steam cleaning.
  7. Mar 26, 2011 at 1:12 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Turtle Wax CD-2 (Engine Detailer). I don't use anything Turtle Wax, but that stuff works amazing...
    I wouldn't use a pressure washer under the hood as suggested before. That is just asking for problems...
  8. Mar 26, 2011 at 1:20 PM
    Rakso
    Rakso [OP] CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Can I use the $5.99 Lowes garden gun hose? lol
  9. Mar 26, 2011 at 1:26 PM
    toyotatacomaTRD
    I don't think you would have a problem with a garden hose, but the pressure washers just have too much force for under the hood...
  10. Mar 26, 2011 at 1:27 PM
    tinker_troy
    T R O Y
    WY/SD
    I do it all the time, no problems. I don't put nozzle right up against anything but if you don't feel comfortable with that I would suggest a good cleaner and a garden hose.
  11. Mar 26, 2011 at 1:29 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Another vote for the car wash.....just don't put the hose right next to the engine and you'll be fine.
  12. Mar 26, 2011 at 1:32 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
  13. Mar 26, 2011 at 1:32 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
  14. Mar 26, 2011 at 1:41 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    I wouldn't recommend a pressure washer, don't know if there is any harm to be done, but it seems like a lot of pressure and risk for something to wrong?
  15. Mar 26, 2011 at 1:45 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    simple green
  16. Mar 26, 2011 at 1:50 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Works great for me.
  17. Mar 26, 2011 at 1:51 PM
    steviestyles
    Colorado Springs
    Bone Stock
    Check out the detailing section. Many people have used the pressure wand at the car wash without any issues; including myself. I've washed off my engine over a dozen times; I probably do so 3 times a year. The thing is you stand back from the engine bay a few feet and you'll be fine; let the misting water do the work as opposed to point blank rinsing off the engine and bay.. A lot of people are concerned with the term pressure washer when in reality the water coming out is misting rather than blasting. If you ever use the do it yourself car wash try rinsing your hand off with the "rinse" setting the pressure isn't that high.
  18. Mar 26, 2011 at 1:58 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    I would lie if I said I haven't done it (on another truck), and never had any problems other than tearing the sound dampening foam on the underside of the hood. Just wih my baby now I don't like to take any chances, a good old hand scrub for me on the engine. Like I said, I know of no actual problems related to it, just the possibility of something happen.
  19. Mar 26, 2011 at 2:05 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    I use the pressure washer/steamer at work probably every other month. When I gets dirty I spray it down. I'm kinda cautious bout usin sprays and degreasers on my engine. Some of em will take the coating off aluminum and actually start to eat away at the metal. I've seen a couple people make bad mistakes and spray their new aluminum wheels with an engine cleaner/degreaser then spray em off n they're ruined.
  20. Mar 26, 2011 at 2:10 PM
    steviestyles
    Colorado Springs
    Bone Stock
    Well the good thing is there is no sound deadener on the hood of our trucks to wash off. As long as you remember to check your oil dip stick and all the caps to your fluids you'll be fine. As for the possibility of something happening, that can be said about anything you do in regards to anything. Relieve your fears, you'll be fine rinsing your engine off of at the Car Wash.
